Advice on 6V vs 12V?
Thanks for all the help.
Some background:
- The truck has not run since 1990 - at least per the inspection sticker
- I bought the truck earlier this Spring from some guys who clearly got the truck "running" in order to sell it. They knew nothing about the truck in terms of history
- The truck came with a 12V battery installed
- Most of the bulbs were burnt out - these I replaced with 12V versions
- The battery charge indicator light has been lit since I bought it
- I've driven no further than ~4 miles, and that seemed to produce some smoke from the wires at the generator
- I see a 6V relay for the flasher, and no ballast resistor
- The solenoid looks original
- The tag on the generator reads 7V / 35 amp
- The 12V bulbs seem to burn a little dim, but not overly so - see picture
Tonight's testing:
- I measured 12.74V at the battery before starting
- 12.55V while running
- The wiring diagram shows three connections on the regulator plus a ground. I measured 9V at the "A" port (the one at the bottom) of the regulator
- Because I was so worried about the now worse leak on the carb, I totally forgot to make sure the engine was at 1500rpm. Ugh. The carb is off again, but I guess I can put it back on and get the engine up to 1500 again if these results aren't conclusive.
Some background:
Tonight's testing:
I totally agree. See if you can borrow a 6 volt battery and give it a try. Hopefully the generator and regulator haven't been fried.
This truck needed a lot of work, and up until this project, I've never done anything more complex than change my pads and rotors.
I only have two (initial) goals:
1. Make the truck fair-weather drivable for ~3 mile trips to Home Depot / the grocery store and maybe the very occasional ~10 mile trip to work.
2. Do all the work myself and learn as much as I can along the way.
I don't plan on adding any modern accessories. Brighter lights would be nice but not essential. And easier starting sure wouldn't hurt (the starter does turn that motor over fast with the 12V that's currently installed!).
I ordered an Optima 6V last night for $112. I'm interested to see if that solves some of my problems. And if I decide to go 12V in the future, I'm only out that $112.
Another detail suggesting this truck was still setup for 6V positive ground: the positive side of the coil is connected to the distributor.
After rebuilding the carb (no leaks it seems!), I swapped in the new 6V battery - positive ground. No more battery light, and although the starter spins a little slower, the truck starts right up and seems to run just as it did before.
Cool!
I measured about 6.2V at the battery, rev'd it up a bit, and didn't really see a change.
Same thing at the regulator - about 6.2V without no real change after adding some rpms.
Again, after adding some rpms, I disconnected the battery, and the truck died.
Crap!
I guess I did fry the generator running it at 12V....
More testing needed, but it doesn't look good for the gen....
Cool!
Crap!
