My 250 xl's has gone missing a sticker, but I can't track it any better than that. Was supposed to arrive on the eighth. Only two things I have that I could see potentially causing a hold back are the elocker and upfitter switches.
Any real information would be great. I am starting to feel like Bob Seegar:
Out past the cornfields where the woods got heavy
Out in the back seat of my '60 Chevy
Workin' on mysteries without any clues
Workin' on our night moves
Tryin' to make some front page drive-in news
In the summertime
In the sweet summertime
In the summertime
Just what we needed. Some background music in this thread.
It may very well suck to keep hitting snags with our new truck orders but my faith lies in the fact Ford is making 110% certain these trucks are spot on when they get into our hands. This was a huge overhaul for the SD, I kind of expected delays.
No trailer camera here. Platinum ultimate package is common. Something there probably Causing an issue?
Platinum Ultimate (96P) contains the cameras. As per order guide:
PLATINUM ULTIMATE PACKAGE (96P) Availability:
● Optional on Platinum
Includes:
● Adaptive Cruise Control and Collision Warning with Brake Support
● Lane Departure Warning
● Moonroof (Twin Panel)
● Ultimate Trailer Tow Camera System (includes 360 Camera plus
LED Camera)
Includes:
LED Camera)
I think my Lariat has this option. (On edit I got the 618A option without the adaptive Cruise control)
Reason: options
I hope you are right and yours was able to make it through. I see on another thread that there is a hold due to lack of wire harnesses now. The trailer cam requires a different harness on the truck and 12 pin plug in the bumper. Somebody knows for sure but it isn't me. I'm guessing like everybody else.
The trailer camera package come with the camera, 30 ft of cable (i believe it was 30, additional sections are supposedly available) and the special plug you replaced the one on the truck with. Shouldn't be anything special on the truck.
For example. My truck has the ultimate camera package, but i didn't order the trailer camera right off the bat. I can add this on after the fact. The order guide has this as a "Dealer installed accessory".
Fidel, my apologies. I should have been a bit more clear about what I was referring to. I agree with you that the issue probably isn't with the availability of the trailer mounted camera or it's harness. That component could be sent later and should not hold up production. I think the issue is with the harness on the truck itself. If you have ordered the trailer camera, or the tow tech option or the platinum ultimate package, your truck must have option code 874 installed at the factory. It is described here:
Ultimate Trailer Tow Camera System (includes Rear View Camera, 360 degree camera system, rear CHMSL camera, Trailer Reverse Guidance and LED Center High-mounted Stop Lamp); display in center stack screen; NA w/Pickup Box Deleted (66D)
874
This package (874) is what contains the special harness. It runs to the rear cameras, the rear 12 pin plug, and all the way to the dash.
