HELP!! 6.0 problem.
Old Aug 11, 2016 | 07:35 PM
Ryanthomasmoore123's Avatar
Ryanthomasmoore123
HELP!! 6.0 problem.
So I looked all over multiple forums and decided to post my own thread on this because I'm lost. Couldn't find exactly what I was looking for...
So I have a 2003 6.0 king ranch w/ 164k on it.. EGR delete, high pressure oil pump, coolant filter and SCT tuning. A couple months back I had a coolant flush done. After about a week the coolant tank was empty.. Engine heated up due to loss of coolant.. I flushed system again and put ford gold coolant back into the tank. (5 gallons). A couple days later and coolant was very low and engine heated up?? There are no signs of leaks anywhere...Added water and it cooled back down. I'm lost. EGR is deleted but no studs done..... YET. I'm supposed to go on a long trip tomorrow.. All the help needed here!!! Thanks.
Old Aug 11, 2016 | 08:28 PM
whalerron's Avatar
whalerron
Leaking head gaskets?
Old Aug 11, 2016 | 08:36 PM
Pocketlint's Avatar
Pocketlint
Hopefully one the mods will see your post and move it to the 6.0 forum, the guys there are pretty knowledgeable and might be able to give you some direction of what to look at
Old Aug 11, 2016 | 08:51 PM
Don Naslund's Avatar
Don Naslund
Have your degas cap tested. Also don't overfill the bottle. Fill the bottle to the low mark only. Is the coolant fairly new?
Old Aug 12, 2016 | 05:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 6.0L PSD forum.
Welcome to FTE and good luck!
Old Aug 12, 2016 | 07:07 AM
LakelandFordParts's Avatar
LakelandFordParts
Former Vendor
I was thinking this was a possibility but if 10 gallons of coolant had leaked into the oil I would think the motor would be acting up already or dead.
Old Aug 12, 2016 | 07:58 AM
catapeed's Avatar
catapeed
If you have lost 10 gallons of coolant have an EGR delete and have NO signs of lost coolant Than you most likely have a head gasket leak, Smell your exhaust is it sweet smelling? Is there a white color to it? I check them by teeing a gauge into the coolant return line and mounting it on the driver side mirror I than go and do hard launches and if the gauge spikes up than I know I have a leaking head gasket.
This is my setup and I tee it into the return to the Degas bottle.
Old Aug 12, 2016 | 10:02 AM
whalerron's Avatar
whalerron
It is possible to have head gasket leaks between the cooling jacket and the cylinders while the oil passages are still sealed.
Old Aug 12, 2016 | 10:40 AM
Ryanthomasmoore123
Thanks for the quick replies! Truck is on a road trip from Georgia to Illinois today so pray for me truck is 5 hours in and so far so good....knock on wood
Old Aug 12, 2016 | 02:09 PM
04superduty6.0's Avatar
04superduty6.0
whalerron, I had a leak between the cylinders and the cooling system. It would pressurize the cooling system and the cap on the degass bottle would puke, I put a gauge on the cooling system and that's how we figured it out. Coolant never made it to oil. I would loose around a gallon to a gallon and a half before I would refill it.
I still have the gauge hooked up to watch the pressure. Highest I've seen so far was 10 PSI pulling around 14K trailer up a pretty good grade. ECT hit 220 and EOT hit 230, fan came on at 218 and cooled it all down.
Old Aug 12, 2016 | 02:57 PM
Ryanthomasmoore123
Hmm interesting.. My degas bottle doesn't puke at all! I'm 9 hours into a 12 hour trip and all is good...
Old Aug 12, 2016 | 04:24 PM
AGE mechanic's Avatar
AGE mechanic
Be sure to turn your heater on for a few min and get everything cycled throughout. Sounds like you could be good, just needed to gulp.
Old Aug 12, 2016 | 05:15 PM
catapeed's Avatar
catapeed
10 gallon gulp?
Old Aug 12, 2016 | 06:26 PM
AGE mechanic
Originally Posted by catapeed
10 gallon gulp?
I have a difficult time believing 10 gallons in the first place. I was not focusing my attention on that. So, some amount of a gulp is probable. Doubtful it was 10 gallons.
All of this happened after he flushed the system. He states that he's 9 hours drive time with no symptoms at this point. I cant say for certain what will fix his issue. Just trying to be helpful.
Old Aug 12, 2016 | 06:47 PM
Ryanthomasmoore123
Thanks guys.. Just finished a 12 hour drive. No symptoms... I'll keep eyeing temps for a while and coolant level to make sure it's okay. Hopefully it wasn't really anything. Fingers crossed...
