Squealing in mid-front drivetrain. ???
Old Aug 10, 2016 | 09:33 PM
hail destroyer's Avatar
hail destroyer
(78 F-250 Supercab, NP205 case, D44 front, NP435 4 speed.)
When in 4 wheel drive, (low or high range) at any speed above 10 MPH, Im getting a loud squealing/ slight grinding noise somewhere between the T-case and the front diff.
Cant figure it out. Full of the right gear oils, U joints are new, etc
Front t-case output bearing? carrier bearing in the diff? I DONT KNOW. Im open to suggestions. WHAT COULD IT BE?
(For what its worth, it has about 350K miles on the drivetrain, and has been severely abused as a plow and farm truck.)
Thanks
Old Aug 11, 2016 | 08:48 AM
orangeford's Avatar
orangeford
These kinds of things can be tough to diagnose. I have a similar problem but at higher speeds and have I replaced everything. The only thing I can conclude is it is due to my lift and resulting driveline angle.
I suggest you try some different things like eliminating certain components as a test.
Examples
Remove drive shaft and take it for a drive in 4 wheel with hubs freewheeling and then again with hubs locked. If no noise in either condition it is likely driveshaft or u joint related. If you still have a noise with the drive shaft out if it does it with hubs freewheeling then it might be something in the transfer case.
Check to see if the driveline is indexed properly so ujoints are in phase. Could be wrong or too tight u joints or the slip joint is loose or the output bearing in the case, the front pinion etc.
rob8210
13
Jun 23, 2019 09:23 PM
Rannoch
Dec 22, 2016 01:47 PM
F350Man79
Dec 30, 2015 08:53 PM
Fullcrew7.3
May 4, 2011 04:37 PM
jphatem
Offroad & 4x4
Mar 3, 2003 06:10 AM
