Purpose of "Extra Heavy Duty Alternator" and "Medium Duty Battery"
Under what circumstances might I wish I had selected the "Extra Heavy Duty Alternator" (+$85) or the "Medium Duty Battery" (+$210) options on my 250 Platinum?
This truck will be our daily driver and will be used to occasionally tow a 27' Airstream trailer.
on
Otherwise, I think the dual alternators would be needed if you start mounting accessories that draw lots of power.
Depending on what packages you select when ordering, they might be included automatically. On a cold morning when the rapid heat and four seat heaters are all going at once, that's a fair amp load. My order just included the duals and I didn't have to select it.
Thank you. I probably should have used the word "benefit" instead of "purpose" in my title. I added only the Platinum Ultimate package in my original order. 6.2 gas engine. No Upfitter switches. I have not yet received a VIN and was just wondering if there might be any reason to edit my order to include either of these two items.
I used to drive an Audi A8 with a heated steering wheel and 4 heated seats. That car had a 150A Bosch alternator and never had a shortage of electrical power. The most basic battery in the Super Duty is 157A. The diesels can hit a ridiculous 377A between two alternators (mine is configured this way automatically due to options ordered).
I think really the only time where more juice would be appreciated would be operating a 12k lb winch, or maybe a plow. But I still think the 157A would be OK.
I think on a Platinum 6.2L, you're going to get at least 200A, which is way more than enough. But like I say, more power is always a good thing!
Notice to there are numerous alternator options. Standard, extra heavy duty, extra extra heavy duty, dual, heavy duty dual (note that only 1 of the 2 is heavy duty). This is from the order guide. A little hard to read cut and paste from the PDF. Options such as cab heat, camper pkg, upfitter switchs all play into mandating the options.
Extra Heavy-Duty Alternator – 200 Amp w/6.2L
engine; 220 Amp w/6.7L Power Stroke® Diesel
engine (required w/Snow Plow Pkg.(473),
Upfitter Switches (66S) or 110V/400W Outlet
(43C); on XL and XLT NA w/Snow Plow Pkg.
(473), Upfitter Switches (66S) and 110V/400W
Outlet (43C) is ordered together)
Extra Extra Heavy-Duty Alternator (req. 6.2L
engine; 240 Amp; required w/Snow Plow Pkg.
Dual Alternators (req. 6.7L Power Stroke®
Diesel engine; required w/Snow Plow Pkg.
Outlet (43C) is ordered together; total of 332
Amp)
Dual Extra Heavy-Duty Alternator (req. 6.7L
Power Stroke® Diesel engine; total of 377
Amp; required w/41A Rapid-Heat Supplemental
Heater)
Amp)
Heater)
I am going with the upgraded alternators for the sole purpose of getting additonal charge going to the batteries in the 5th wheel. I have 4 6 volt batteries and just like to have them topped off when we take them out.
Not sure it will make a difference but the cost is not a lot so I will give it a shot.
BIGTRUCKBIGRV
2017+ Super Duty
18
03-02-2021 06:12 PM
