99 7.3 dies when warm
Old Aug 10, 2016 | 01:05 AM
Zack12's Avatar
Zack12
I have a 99 7.3, i took off driving the other day and after about 10 mins the truck just dies like I shut the key off but everything was still on. I tried to restart it and it would fire for just a sec then die. I set for about 15 mins and tried again it fired up and ran about 5 mins then the same thing. I had a buddy hook it up to his scanner and it has a p0605 and another icp code.. We changed the icp then erased the codes.. Ran some rest through the scan took with the truck running and no codes so we took it for a drive made it about 20 mins away and same thing but this time has the p0605 code again. Could the pcm be bad? I also noticed the electric pump is always on all the time it will cycle at least 30 seconds every time the key is turned??. Anyone have any ideas, thanks
Old Aug 10, 2016 | 05:26 AM
Pikachu's Avatar
Pikachu
What was the ICP code, exactly? Is there a chip/programmer/tuner installed? The fuel pump will run continuously when the engine is running, and for 20 seconds if the key is turned on without starting the engine.
Old Aug 10, 2016 | 06:06 AM
AllaboutMPG's Avatar
AllaboutMPG
has it been getting harder to start when warm lately?
Old Aug 10, 2016 | 08:39 AM
Rikster-7700's Avatar
Rikster-7700
Sounds like it could be an IPR issue? Especially if it seems to do it when the engine is warm. Maybe time to pull clean and rebuild.
Old Aug 10, 2016 | 08:47 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Sounds like o-ring issues somewhere. Either on the IPR or the injectors.
Have you changed the oil recently?
Have you check the oil?
What kind of oil are you using?
These could also be causing problems.
Old Aug 10, 2016 | 09:28 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Sometimes a failing IPR will stop working when hot. Next time it happens dump a cup of ice on it, give it a minute to cool and try to start.
I don't know if this type of failure is due to an issue with the electric or mechanical part of the IPR, so if cooling it works I'd replace the IPR rather than rebuild it.
Old Aug 10, 2016 | 12:24 PM
Zack12's Avatar
Zack12
It's all stock no chips or runners or anything, it only is hard to start right after it dies but when it's cooled off it fires right off. The oil was changed about 3000 miles ago, my buddy works at peterbilt he changed the oil at work said they used delo 10 30. Its right at the full mark no coolant or fuel in the oil. When it's running it runs perfectly fine. I'll try the ipr tonight and see what that does. .thanks guys
Old Aug 10, 2016 | 01:15 PM
LakelandFordParts's Avatar
LakelandFordParts
Former Vendor
I'd have to agree with everyone else, quite possibly the IPR. If that is the culprit you'll be looking at part number F81Z9C968AB... Hopefully it is simple seals like CampSpringsJohn suggested, if so the part number on those is 1807263C1.
Old Aug 11, 2016 | 12:25 PM
Zack12's Avatar
Zack12
Instead of messing around I just went down to Ford bought a new ipr still same thing idled in the drive way about an hour dies would start and die start and die let it sit about an hour started up ran fine for 20 mins then same stuff. Tried starting it died did that 3 or 4 times then it would just turn over so I hit a shot of starting fluid to see was it would do and it fired right off like it isn't getting fuel? Going to replace cps tonight and see what happens. Could it have a plugged return line maybe?
Old Aug 11, 2016 | 12:47 PM
AllaboutMPG
How much fuel in the tank, how's fuel press, have you done any in tank mods?
Old Aug 11, 2016 | 02:32 PM
Zack12's Avatar
Zack12
It has a full tank, fuel pressure is 44-51 52
Old Aug 11, 2016 | 02:33 PM
Zack12's Avatar
Zack12
No tank mods everything is stock
Old Aug 11, 2016 | 02:52 PM
AllaboutMPG
As long as you have that fuel press steady then it's probably not fuel issue. It's time to monitor sensors, pressures, and codes. You may have a low oil pressure to injectors or some other issue. What kind of scanner does your buddy have?
Old Aug 11, 2016 | 05:03 PM
aawlberninf350
It's a Van Gogh
OTOH if that fuel pressure is at idle, then it's not going to be good enough on the road. I think the rule of thumb is minimum 45 psi at WOT. Lack of fuel can also throw a low ICP code.
Old Aug 11, 2016 | 07:32 PM
Zack12's Avatar
Zack12
It doesn't have any codes, his scanner is a modis eems 300
