1995 f350 460 won't start!! Help me!!!!
  #31
Old 08-11-2016, 09:12 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
So now that we know the computer doesn't think anything is wrong, we can start some basic diagnostics.
Does the truck start/run if you shoot starting fluid or carb cleaner down the intake?
  #32
Old 08-11-2016, 09:20 AM
subford's Avatar
subford
subford is offline
Getting the KOEO electrical test code 111 with a cold engine points to a bad ECT sensor. If a bad ECT sensor says the engine is hot when it is cold the engine may not start or may do what your engine is doing.
  #33
Old 08-11-2016, 09:43 AM
Crazychris1981's Avatar
Crazychris1981
Crazychris1981 is offline
Which one is the ECT there are two on top of the intake. If I'm correct one is for the temp gauge and one is for the computer?
  #34
Old 08-11-2016, 09:51 AM
subford's Avatar
subford
subford is offline
The ETC sensor is for the Computer and the Temp gauge sender is for the gauge.
  #35
Old 08-11-2016, 10:00 AM
Crazychris1981
Ok I tested that with my meter it ohm out good to what I read on the internet. Cant remember what it was
  #36
Old 08-11-2016, 10:03 AM
Crazychris1981
What is the IAT for?
  #37
Old 08-11-2016, 10:09 AM
subford's Avatar
subford
subford is offline
The IAT (Intake Air Temperature) tells the computer what the temp is of the air going into the engine.
  #38
Old 08-11-2016, 10:14 AM
subford's Avatar
subford
subford is offline
Was that ohm reading for a hot or cold ECT sensor?
  #39
Old 08-11-2016, 10:44 AM
Crazychris1981
Here is a video of what the truck is doing!!
The thing I looked up gave two ohm readings one was for 80 somethings degrees the other for over 100 degrees. My ohms was In between the two at ambient temperature and its 90 degrees outside.
  #40
Old 08-11-2016, 11:17 AM
subford's Avatar
subford
subford is offline
I could not see the fuel gauge while it was running. The camera keep pointing at the throttle body for some reason.
  #41
Old 08-11-2016, 11:28 AM
Crazychris1981
Sorry I was trying to keep it running. It stays a 40 psi when running 38 psi when you turn on the key. If you pull the vacuum line off the fuel pressure regulator it does nothing.
  #42
Old 08-11-2016, 11:38 AM
subford's Avatar
subford
subford is offline
The vacuum line to the FPR must not have any vacuum while running.
Have you pulled the SPOUT out and if it will run then put a timing light on it and see if it is set at 10 deg BTDC?
  #43
Old 08-11-2016, 12:05 PM
Crazychris1981
Sorry what is the SPOUT?
  #44
Old 08-11-2016, 12:08 PM
Crazychris1981
Is it the little thing by the ICM?
  #45
Old 08-11-2016, 12:25 PM
subford's Avatar
subford
subford is offline
Yes it is.
Spark Output (SPOUT): Desired spark timing information sent from the PCM to the ICM.
The SPOUT shorting bar jumper:
Quick Reply: 1995 f350 460 won't start!! Help me!!!!
