speedometer fluctuates wildly, charge light blinking
Sanded all ground connections
Soldered battery cable connections
Scan gauge showed sporadic inadequate charging
Installed new alternator
Installed new interstate batteries
Brought old alternator to be rebuilt, rebuilder said it was strong as could be, needed no work, high output alternator
Reinstalled old high output alternator
Scan gauge now shows charge output of 13.9 V to 14.1 V
Idiot light still on, flickers like a loose connection, sometimes lights constantly.
Occasionally speedometer fluctuates wildly, when fluctuating like this at idle, the truck will stall, so far it restarts...so far
When it has stalled the speedometer still fluctuates wildly for a few seconds truck will restart and seem fines but this will play out again next day or so
Occasionally ABS light comes on, occasionally water in fuel light comes on and they go away after abit, some times after a restart, not always though
Thought it might be cam positon sensor however not certain with the instrument lights also acting as they do
Have had one cam position sensor open circuit code once,
about to trip out west to Monatana & Colorado and back home to Ma in a couple of weeks, hoping not to be stranded somewhere in between those places!
Any Ideas?
I am wondering if more than one thing is going on. Might the instrument cluster need a rebuild, I understand they go bad. Battery light flickers, stays on, it goes off but rarely, scan gauge says 14.1 volts usually pretty constant, occasionally the abs and water in fuel light on, then they go off on their own. What throws a wrench in it is when the speed fluctuates/surges up it only stalls if I am not moving, like at a light but restarts and off we go. I did have the cam position sensor open code 1 time as well. any how thanks for your response.
went over the alternator connections for the 20th time, ground coming out of alternator and the couple of small 2 wire connection...light is now out.
Water in fuel was on, shut truck off, on restart water in fuel light out.
Seems as though I did see the speedometer flucutating slightly.
Will see how it does tomorrow as I tool around for work.
If you could find a cluster with the same part number, it might be worth your time to swap it in. It only takes about 10-15 minutes. I put a donor one in my truck while the medics were doing their magic, and it worked fine.
Well my battery light is still out. However today the speedo is jumping all around, loss of power, hard time getting out of its own way.
My cluster lights up, though, Guess I will be sending it out. Going to also try the PCM Relay as per Blad3es suggestion
Because I don't know if a bad cluster would affect drivability
Unless a cluster is back feeding power to PCM or something weird
https://circuitboardmedics.com/2002-...luster-repair/
Also, any problems with the windshield wipers? The was a owner that had problems slightly like yours that was caused from a shorted WS wiper motor.
So I popped the hood again to check for perhaps some abraided wire. Sunday,when I was last under the hood I saw the plastic nipple that has a hose attached to it which runs to the degasser bottle was cracked and leaking, I tapped in a metal nipple, coated the threads high temp silicone, reconnected the hose, no leak. In order to do that, I had to move the turbo hose out of the way. Neglected to hook that turbo hose back up... which is why the truck had no power monday... Monday after reconnecting the turbo, I removed the speed sensor from the rear end wiped it cleaned, and so far speedometer has been steady, not acting up yet. I intended to replace the oil in the rear end as well, bought the truck with 80,000 miles on it, now at 124,000, probably has not ever been done thanks for your help
Called circuit board medics, explained what was going on, they said not the instrument cluster, as more symptoms are usually found with it going bad. loss of power to the cluster, power in and out, other components not working etc. Am picking up a Cam Position Sensor today. See it that helps...
