Weird no start problem
Old Aug 9, 2016 | 10:38 PM
mybreathyourlung's Avatar
mybreathyourlung
Originally Posted by Lead Head
Where did you test the PIP signal?
It was step 7 in the follow-through above, so "wire 6" on the ICM. My test light flashed rapidly on and off.
Old Aug 9, 2016 | 10:41 PM
Lead Head's Avatar
Lead Head
So the PIP signal is making it to the TFI module, but the coil signal appears to go out.
Can you hook your multimeter up to the coil positive, and then have someone crank the engine? Does the voltage stay there, or go away?
Old Aug 9, 2016 | 10:43 PM
mybreathyourlung
I tried this earlier today and I can't remember the number exactly but the voltage definitely dropped a lot, I want to say down to 7v? I can try again tomorrow to get an accurate read.
Old Aug 9, 2016 | 10:48 PM
Lead Head's Avatar
Lead Head
Definitely do that, and also verify the TFI module is getting power while cranking as well, and that its ground is good.
Old Aug 10, 2016 | 03:05 PM
mybreathyourlung
Well, the coil gets 10.7v during cranking. The ICM also reads 10.7v during cranking (read from wire #3 in the walkthrough). Both read nothing with KOEO.
I tested ground on the ICM by shaving off some plastic on the ground wire and running my test light from there to battery + and my test light lit up. So good ground.
Old Aug 10, 2016 | 03:40 PM
Lead Head's Avatar
Lead Head
But the ICM output doesn't pulse while cranking? Is the SPOUT connector disconnected while doing this?
If the SPOUT connector is not disconnected, I'd try disconnecting it and see if spark returns. If it doesn't, I'd try returning that TFI module and getting another one. If that still doesn't fix the issue, I'd assume that while the PIP module in the distributor is outputting a signal, it may not be strong enough for the TFI.
Old Aug 10, 2016 | 05:06 PM
mybreathyourlung
Well, I disconnected the SPOUT connector and I got more spark at the coil during crank (before, it was 1 initial spark then nothing). It seemed a little weak, sparking maybe every 2 seconds and it wasn't a strong blue color that (I think) I'm used to seeing, it was a muted yellow (if that counts for anything).
And yeah, the ICM output doesn't blink while cranking, the light turns off.
Old Aug 10, 2016 | 06:53 PM
roboto65's Avatar
roboto65
I know you said you replaced the battery but what voltage is the battery under load is the alternator good.
Old Aug 10, 2016 | 07:47 PM
Lead Head's Avatar
Lead Head
The next test would be to hook the ignition system back up, leave the SPOUT disconnected and see if it runs. See if starting fluid gets it going.
Old Aug 10, 2016 | 08:03 PM
mybreathyourlung
I'll check the battery under load tomorrow. So it's fine to run the truck with the SPOUT disconnected? I know nothing about this feature. I could've tried to start it with it disconnected but I didn't want to risk it. Why it is connected, if running with it disconnected is okay? One would assume it's supposed to be connected. I'll give it a go.
Old Aug 10, 2016 | 08:54 PM
subford's Avatar
subford
The SPOUT wire is an information path from the Computer to the ICM. This is how the computer tells the ICM when to fire the spark plugs.
With the SPOUT out the computer no longer has control over the Ignition system and the ICM will fire the spark plugs at base timing and this should be 10* BTDC.
Spark Output (SPOUT): Desired spark timing information sent from the PCM to the ICM.
Old Aug 11, 2016 | 04:21 PM
mybreathyourlung
Under load the battery drops to 10.7v
I believe the alternator is fine, I have no reason to think otherwise. The battery died because I left a light on overnight.
It won't start, even with carb cleaner going into the throttle intake.
The mechanic down the street said he would check something in the distributor, I can't remember the name but it started with a "P". Any idea what he was talking about?
Old Aug 11, 2016 | 05:54 PM
  #28
subford's Avatar
subford
PIP sensor.
Old Aug 11, 2016 | 07:23 PM
  #29
mybreathyourlung
Im at the point where I've replaced the ignition coil and the ICM and about to purchase a new distributor assuming the PIP sensor is bad. If this doesn't fix the issue then what? There's not much left is there?
I thought the PIP sensor was actually in the ICM somewhere. Interesting. At least I'm learning a lot about the ignition system on this truck.
Old Aug 11, 2016 | 08:03 PM
  #30
Lead Head's Avatar
Lead Head
Well there are only 3 components to the ignition system: The PIP, ICM and ignition coil. If you got power to them, and they're all functioning, you get spark. I suspect the PIP sensor is sending a weak signal.
