1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 F350 4x4 300k Miles Intermittent Vibration
Old 08-07-2016, 12:10 PM
joshcwa's Avatar
joshcwa
joshcwa is offline
Greetings! I have a 99 F350 PowerStroke with a vibration in the front end that only shows up intermittently. She has 300k miles on her and I am pretty sure the front, rear axles are original and the transfer case. The transmission was rebuilt around 70k miles ago and seems to in good shape.
The problem: I am driving at highway speed 40+ MPH, in 2WD, hubs unlocked ( original hubs replaced with Warn manual a year ago ). At random times I will get a vibration in what feels like the front that I can only describe like when you drift onto the rumble strip on the highway or something, but a little less intense. I can feel it in the floor, steering wheel, etc. It's also audible in the cab.
I have figured out I can make the vibration stop by flipping it into 4WD. As soon as I slip the switch, it instantly goes away. But it will come back again, typically within a few minutes. It's not consistent, but sometimes it seems like the vibration starts when I hit a medium sized bump or pothole.
I also recently found that if I leave the hubs locked, the problem goes away.
Other info — about a year ago 4WD was not working, the drivers side front wheel would not lock/engage. I ended up having Ford replace the torrington bearing, which fixed the problem. Not sure if that is related at all, but I did have the vibration before that.
This truck overall in good shape, not a daily driver. It gets probably 5-7k miles a year.
Appreciate any help / insight you can provide, but I'm leaning toward "it probably needs a new front end" at the moment. :\
Thanks!
jimlj
05-26-2017 01:42 PM
Superduty ROCKS
02-27-2014 02:38 PM
Gandalf.alpha
03-24-2010 12:57 PM
Dan Taylor
03-04-2010 05:02 PM
gnrrbert
15
02-21-2010 08:28 AM
Quick Reply: 99 F350 4x4 300k Miles Intermittent Vibration
