help with trailer size
Old Aug 7, 2016 | 11:54 AM
Nick8289's Avatar
Nick8289
I have a 2006 ford explorer with the 6clcy, axle code 45, GVWR of 6180, front GAWR 2960 rear GAWR 3400 how can I figure out what weight trailer I can pull without damaging the truck? thanks in advance guys.
Old Aug 7, 2016 | 03:41 PM
wallacemf's Avatar
wallacemf
Looks like with 3.55 rear differential, you are around 3200# max, with 3.73 rear differential you are slightly over 5000# max. See Ford 2006 towing guide below...
https://www.fleet.ford.com/resources...guideApr08.pdf
Old Aug 8, 2016 | 09:18 AM
Nick8289's Avatar
Nick8289
how can I tell what rear differential I have? I am not really a big truck guy... thanks again.
Old Aug 8, 2016 | 11:11 AM
wallacemf's Avatar
wallacemf
Axle code 45 is a 3.55 conventional, meaning it's not a locking or limited slip differential. There is a table at the link below....
https://www.ford-trucks.com/forums/1...xle-codes.html
Old Aug 8, 2016 | 10:21 PM
cyncwby's Avatar
cyncwby
Also remember, it's not how much your truck can tow, it's how much it can handle and stop safely.
Old Aug 9, 2016 | 08:56 AM
seventyseven250's Avatar
seventyseven250
Also remember that the salesman at the trailer dealership is NOT a reliable source of information on what you can or should be towing. They make more money on larger trailers.
Old Aug 9, 2016 | 10:09 PM
finallyo3gt's Avatar
finallyo3gt
Second this. I let my wife and a salesman talk me into a 4600# 26' TT to pull with a 2015 Explorer. Trailer rating of 5000#, total gross of about 10,700. Problem is Explorer weighs about 5100# itself. Add 5 passengers and gear, and I go about 12,500. I will say, we have the sport, and the 3.5tt ecoboost is more than capable. Actually gives my 7.3 a run for tge money. And plenty of brakes. But.... you feel the weight in the suspension, and the wheel base is a bit short. Add 500-800 pounds to the dry weight of the trailer, and don't forget passenger weight. Check the tow guide, find max combined gross, subtract passenger weight, the mentioned 500-800# in gear, and now you have an idea on trailer weight.
Old Aug 15, 2016 | 12:25 PM
Chuck's First Ford's Avatar
Chuck's First Ford
the posted weight of a trailer .. may or may NO include added stuff.. battery, propane tanks, upgraded interior things.
my trailer is tagged in 2 different places at 7,500 pounds.. but it scaled EMPTY at 8,300 pounds.
just something else to remember.. even the trailer itself can lie.
Old Aug 16, 2016 | 11:19 AM
SpringerPop's Avatar
SpringerPop
It's always a good idea to run a new (to you) trailer across the scales, preferably one tire at a time.
There will almost always be differing weights front to rear, and also side to side.
Pop
Old Sep 17, 2016 | 10:09 AM
5851a's Avatar
5851a
What all of the above have said. My with can load up 1000lbs of "Essentials" in a hour without breaking a sweat. Me I just hook up, unhook, drive. Oh, guess there is that 100lbs of "beverages" that I throw in. Water is a little over 8lbs a gallon, if you camp without full hook ups and fill 3 30 gallon holding tanks that's a cra*load of weight. Anyway smaller truck=white knuckles, big truck= I'm kind of sleepy how much further.
Old Sep 17, 2016 | 03:00 PM
seventyseven250
Agree, it's surprising how much weight you can pack into even a modest trailer. If you carry firewood, that can add up fast as well.
And if you like canned beverages, a six-pack is only a hair under five pounds. I drink quite a few six packs . . . .
Old Sep 17, 2016 | 04:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I don't even care how much a 1.75l bottle of Barcardi weighs..... it's goin' in there!!! Along with a 6 pack of Coke.
Old Sep 17, 2016 | 10:42 PM
EDC8008's Avatar
EDC8008
EASY, we all know some must have their adult libations.
I have to bring my guns with me they way about 100 Lbs total but man the part that adds up is the ammo 35 to 40 lbs a box adds up fast.
dapado
Feb 9, 2013 02:03 PM
mchbts
24
Feb 15, 2010 09:05 PM
johny_maple
16
Jun 6, 2003 01:11 PM
dnarine
All Things Towing
May 2, 2003 05:25 PM
bigm2
All Things Towing
May 6, 2001 10:17 PM
