E350 diesel: battery question
Old Aug 7, 2016 | 07:25 AM
johnwassink's Avatar
johnwassink
One of my batteries on my van is on the frame rail. The box rusted out so I routed the battery into the back of the van for now. The van wouldn't start because the batteries were low. I charged the battery in the front engine bay overnight but it did not charge the 2nd battery, does that mean there's a disconnect between the two batteries? I thought they were in parallel.
Thanks
-John
Old Aug 7, 2016 | 08:02 AM
mueckster's Avatar
mueckster
There should be no disconnect. It means that one or both batteries, or a connection(s) are bad. You need to isolate the batteries from each other by disconnecting the ground cable from one battery and test them individually.
Old Aug 7, 2016 | 08:31 AM
johnwassink
Thank u very much I will do that
Desert-Rat
21
May 9, 2023 04:48 PM
johnwassink
15
Oct 18, 2019 04:09 PM
timmygyu
Feb 16, 2012 05:43 AM
JoePa2
Oct 21, 2011 11:34 AM
rshawiii
Electrical Systems/Wiring
Jun 24, 2004 12:49 AM
