summit racing column
Old Aug 4, 2016 | 11:23 AM
jerryst's Avatar
jerryst
Has anyone ever used a 30 inch tilt column from Summit Racing? I am looking to use this one for my power steering swap on my 55 F100.
Thanks
Jerry
Old Aug 4, 2016 | 01:49 PM
Rusted56's Avatar
Rusted56
Be careful what you use, and make sure you know what brand it is, there's some bad ones out there.........
http://www.lvvta.org.nz/documents/in...ng_Columns.pdf
The study was done in New Zealand, I think, but very thorough........
Old Aug 4, 2016 | 02:00 PM
F1 Mike's Avatar
F1 Mike
That's a great document. Thanks for posting the link.
Old Aug 4, 2016 | 02:06 PM
dbran451's Avatar
dbran451
summits column's are made by flaming river I have one it's been fitted but not permanently installed
Old Aug 4, 2016 | 02:07 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Very useful link, thanks' for posting it.
Old Aug 4, 2016 | 06:02 PM
ChuckRob's Avatar
ChuckRob
I tried a low dollar column and learned a big lesson. Replaced it with an Ididit.
Ididit is made in the US and the difference in quality really shows. Here is a little tip. If you plan on installing cruise control order your column with the switch installed. Running the wire through the column as an add on is a real bear, ask me how I know.
Old Aug 4, 2016 | 06:18 PM
yamagrant's Avatar
yamagrant
I had bought a CPP column. I took it all apart to shorten it 2''. I have done a lot of steering column work on GM cars when the columns were smashed during theft's. I found the CPP column was not that much different in quality and construction. This is my opinion, and I will go with what I have. Mine is a tilt meant for floor shift, and no ignition. Good luck with your choice.
Old Aug 4, 2016 | 07:39 PM
rdemilt's Avatar
rdemilt
I have a CCP column in my F1, Tilt - no ignition switch - column shift. In my opinion it is low quality, the tilt mechanism does not lock up well and the shaft rattles every time Im on a bumpy road, because the bushing at the bottom of the column is a poor fit. A new column is on my short list, for piece of mind and safety reasons.
Old Aug 4, 2016 | 08:44 PM
geoffthepilot's Avatar
geoffthepilot
about 5 years ago I tried to install one of the summit racing columns. It was very cheaply made and gave me a lot of problems. I ended up sending it back. I really like most of the summit brand stuff but that one was a lemon. maybe they have improved them since then though. I replaced it with an Ididit one and I'm very happy with it.
Old Aug 5, 2016 | 06:29 AM
49willard's Avatar
49willard
I think that this is a case of getting what you paid for.
Old Aug 5, 2016 | 08:48 AM
artscott61's Avatar
artscott61
Veteran: Navy
A column was in and still in my truck when I bought it. Question , how can you tell who manufactured it ? (column shift and tilt no start)
Old Aug 5, 2016 | 11:33 AM
ChuckRob's Avatar
ChuckRob
Here is how to identify and Ididit column
Old Aug 5, 2016 | 02:39 PM
Rusted56's Avatar
Rusted56
The article posted shows how to identify each column as well.
Old Aug 5, 2016 | 02:55 PM
tractormanbill's Avatar
tractormanbill
tractorman
I bought a CCP for around $300, installed it and didn't like it so I put it on Ebay and bought a Flaming River.
Don't remember exactly why I didn't like it.
TractormanBill
Old Aug 5, 2016 | 03:06 PM
Rusted56's Avatar
Rusted56
I originally had a CPP column as well,, but became concerned after researching a bit, and finding that article. I called up Mid Fifty, they took it back (never installed), and sold me an Ididit.
