Illinois Chapter Join Chapter Leader: wpnaes
Illinois Chapter August 2016 BC & Chat thread
Old Aug 1, 2016 | 09:34 AM
BIGKEN's Avatar
BIGKEN
Good morning IL...and...wandering miscreants...Happy August!!!
Old Aug 1, 2016 | 09:37 AM
56panelford's Avatar
56panelford
Good morning everyone..
Old Aug 1, 2016 | 10:40 AM
tiny1's Avatar
tiny1
Moderator & CL
Morning gang.....hope that your Monday is going well.
Old Aug 1, 2016 | 07:42 PM
56panelford
Good evening Illinois..
Old Aug 1, 2016 | 08:13 PM
KOESTNER's Avatar
KOESTNER
Good evening Illinois and a happy August to all!
Was 86° here today, with a carbon copy for tomorrow.
The 90s return on Wednesday and run thru the weekend.
Mowed the front yard and spread bug killer on the back yard.
Old Aug 1, 2016 | 08:16 PM
56panelford
Hello Rick..
Old Aug 1, 2016 | 08:28 PM
KOESTNER's Avatar
KOESTNER
Howdy John!
Did you do anything worth writing home about?
Old Aug 1, 2016 | 08:42 PM
56panelford
Not really, didn't get out to the shop until late morning and finishing prepping the front gravel pan and cleaned up the shop a bit then after lunch wiped everything down with wax/ grease remover and set things up for spraying tomorrow..
Old Aug 1, 2016 | 08:54 PM
KOESTNER's Avatar
KOESTNER
That sounds like a busy day. So are you ready to shoot some color?
Old Aug 1, 2016 | 09:00 PM
56panelford
Not yet Rick, tomorrow I'll get the high build on all the front sheet metal. I still need to spray the epoxy on the rear fenders yet but can spray the high build shortly after that. Then I'll start the sanding on the cab and box then spray the color on them. After that it will be wet sanding and polishing before setting them back on the frame..
Old Aug 1, 2016 | 09:04 PM
KOESTNER's Avatar
KOESTNER
Still a lot of work to be done. Just keep plugging along.
Old Aug 1, 2016 | 09:08 PM
56panelford
I think the next round of sanding should go fairly quick because I have it all in pretty good shape now..might end up being a month behind what I had first thought..
Old Aug 1, 2016 | 09:11 PM
  #28
KOESTNER's Avatar
KOESTNER
You're retired, you're not behind.
Old Aug 1, 2016 | 09:15 PM
  #29
56panelford
I'll have it painted one way or another before the year is up..
Old Aug 1, 2016 | 09:20 PM
  #30
KOESTNER's Avatar
KOESTNER
I don't know when it starts getting cold there but I would think that there is enough time before the white crap flies.
