Displacement???
Old Aug 18, 2003 | 10:53 PM
72f250CS's Avatar
72f250CS
Displacement???
OK GUYS, I GOT A 360/390 (OR SOMEWHERE IN BETWEEN). THE PISTONS ARE 60 OVER, ORIGINAL HEADS, I THINK THE ORIGINAL CAM AND CRANK. I MEASURED THE STROKE AND IT CAME OUT BETWEEN 360 & 390 STROKES( DONT REMEMBER EXACT AMOUNT). IS THERE ANY WAY TO FIND MY ACTUAL CID?? IT HAS TONES OF TORQUE NOT MUCH FOR TOP END THOUGH.
ANY HELP WILL BE REWARDED WITH THE BEST OF THANKS.
Old Aug 18, 2003 | 11:22 PM
redneck hillbilly's Avatar
redneck hillbilly
Displacement???
You need to measure the stroke again. Is the engine still together? Know any numbers (rods, crank)?
Old Aug 19, 2003 | 11:07 PM
72f250CS's Avatar
72f250CS
Displacement???
Unfortunatly I dont know any of the numbers, it is my daily driver. Had to do heads due to a sucked valve, almost 1/8 in into head. cleaned piston tops while heads were off. I dont have the stroke specs anymore so if someone can give them up that would be great. Thanks again.
Old Aug 19, 2003 | 11:52 PM
Bob Weiler's Avatar
Bob Weiler
Displacement???
Need more info. The stroke on a 360 is 3.50, on a 390 3.78. Which do you have? This is vital in figuring CID. I have the formula for determining CID somewhere I'll see if I can find it and send it to you. It is something like-borexborexstrokexstrokexsome number. I'll check it out.
Later,
Bob
Old Aug 20, 2003 | 02:12 AM
willowbilly3's Avatar
willowbilly3
Displacement???
borexborexstrokex.785x no. of cylinders
Old Aug 20, 2003 | 05:52 PM
FE427TP's Avatar
FE427TP
Displacement???
if it's somewhere in between it's not a 390, simple eh? if you measured from the deck the longer than 3.5 would be because the piston doesn't come to the top of the deck at the top of the stroke
