I don't have pics but made my own and set it off to passenger side so header clears all steering. I had a Jag front end. Must have had the engine in and out twenty times to get the side by side and angel correct. I made wood mock ups but all of that went with F3 when I sold it.
I have a 1979 Nova subframe in my 50 F1, virtually the same as your 77 camaro clip. I have my 5.0 centered, with plenty of clearance. Stock Ford motor mounts on the engine going to fabricated brackets on the Nova crossmember.
I used a rear sump oil pan and pickup from an older Bronco or Econoline.
The headers I used are from Speedway.
I have the motor sitting pretty high in the frame, and this position gives me over an inch clearance to the firewall.
The small block Ford is a pretty long engine, so verify your radiator clearance before you weld in any mounts. I went with a Ford Racing short water pump to gain some room, or you can go with a stock serpentine setup, which is even shorter.
Good luck!
Here's a view from the other side, showing how much clearance there is to the oil pan. It looks like even a stock oil pan from a Fox Body Mustang would clear.
