temp gauge not working
Old Aug 18, 2003 | 08:02 PM
bignoggin's Avatar
bignoggin
Question temp gauge not working
My temp gauge is down past c I put a new temp sending unit in at the heater hose connection. The fuse is good what else can I try? Truck is a 93 F-150 with the 4.9L
Old Aug 18, 2003 | 10:06 PM
pfogle's Avatar
pfogle
a real temp gauge. That thing in the dash in notoriously inaccurate.
Old Aug 18, 2003 | 10:29 PM
fishin1976's Avatar
fishin1976
That is the wrong thing to replace for the guage in the dash. The one you want to replace is on the passenger side block under the rear exhaust manifold between cyl # 5 and #6. Small fitting with one wire on it. Usually never goes bad, but.......
Old Sep 14, 2003 | 09:41 PM
Bobb8791's Avatar
Bobb8791
Had the same prob. To check the sensor, turn ignition key to run position, and take the wire from the temp sensor and groung it to the block, the look at the gauge in the dash. If the gauge goes all the way up, the sensors bad , if not then its the gauge, or the wiring if your real unlucky. I had a bad gauge, Ford dealer wants $145 for the gauge if you have a tach. Most junk yards will sell the entire cluster for 120 used. Or Probably the best way is to get an autometer gage and sensor for 80 dollars and a 40 made to fit f150 gauge pod.
Old Sep 15, 2003 | 11:16 AM
kennyrrt's Avatar
kennyrrt
Where is said sender on my 89 460? I've been chasing this thing for a while and still don't know if lookin' under the right rock.
Old Sep 15, 2003 | 09:00 PM
kennyrrt's Avatar
kennyrrt
I fixed it! See under Lariat cab near the top of the thread.
