75 F150 need info
Old Aug 18, 2003 | 07:49 PM
71LTD390's Avatar
71LTD390
Question 75 F150 need info
I just bought a 75 F150. I am going to pick it up later this week. I need some info on the door sticker codes. The truck is all original and has 116K. It's been sitting for about seven years outside and started occasionally. Was stored inside from 1978-1988 and not driven. Body has minor rust. It is a Custom trim level but has bright winshield and rear window mouldings, drip mouldings, west coast mirrors, cab marker lights, and the small bright dog dish hubcaps. It also has a knitted vinyl seat. It has a 360 with a 3 speed manual. Runs like a top. No smoke but a bad exhaust leak near the manifold or head pipe. Built in March 1975. Oh, it also has a white top. I've never seen a Custom this dressed up from the factory. Has factory AC. Here are the codes I need:Color WM, DSO 17, Body 624, Axle 15J, Trans C. The sticker on the door jam is not filled out completely. Only the VIN, weight ratings, and date of manufacture are typed in. Why is this? I got the codes off of the metal plate on the drivers door. No interior/exterior trim codes are filled in. Seems odd. Any help appreciated.
Old Aug 24, 2003 | 05:11 PM
farmtruck75's Avatar
farmtruck75
75 F150 need info
Best I can get is as follows:
Color: W=Wimblebdon White M=Med. Green Glow
DSO 17= Washington (District)
Trans C= Manual 3-sp
Axle 15J= Ford 3750 3.25
Body 624= 6 Green trim/4 ?maybe custom bench/ 2 style side
Old Aug 24, 2003 | 06:20 PM
Mil1ion's Avatar
Mil1ion
75 F150 need info
624 means the body code = (62)= something cab
with (4) styleside box
The J in 15 J means it has power steering
Old Aug 24, 2003 | 06:30 PM
71LTD390's Avatar
71LTD390
75 F150 need info
Thanks! I picked up the truck yesterday. I gave the wrong Body code. It is actually 6Z4. I am going to get a set of Shop Manuals. Just wanted to find out what color it was. I have the Standard Catalog of American Trucks and it lists Med. Green Glow as an optional color. Doesn't give code breakdown though. Aside from stale gas, a rusty gas tank (plugs fuel filter) it runs great for sitting so long. Gas actually has a red look. Thanks for all the info.
