Nothing has happened lately but I have had a few dreams about breaking down..... The truck does make a weird sound when it first starts in the cold almost like a rattle. Maybe the power steering pump or the air pump.
Well since last post, new front end done. remove noise done.
replace leaking fuel line done but still leaking as one last section not replaced. Parts on hand.
I need to put in new exhaust manifolds and up pipes. Parts on hand.
Since I will have it torn down I may as well do the e fuel too. parts on order.
Well I'm waiting on the E fuel from Mark Fugazzotto I was thinking on how the E fuel does not have a heating unit in it. Just how does that change thing in cold months? I don't even know if mine works.
Most remove the bowl heater as it will short out someday and take out the PCM fuse.
Fallon may be a little colder in the winter than here in Reno but my truck fires right up in the winter with efuel. No fuel or block heaters, just the glowplugs.
I have to cycle my plugs 2 or 3 time it get it to fire up. If its plugged in no problem.
Fuel heater has nothing to do with starting on the stock fuel system. The heater is in the bowl, and you'd have to do a lot of cranking before the warmed fuel would get to an injector...
I live where the winters are darn cold... no fuel heater... no problems.
I just youtub'ed the Armature. Now I know and will check on that.
I bought the kit already and just need time to install it.
waterpump last weekend, radiator tonight, steering rack tomorrow night, girls car front end rebuild, mower deck bearings and then maybe ill get to it after I mow the grass
