Anyone good with plows need help?
Old Jul 22, 2016 | 11:49 AM
kyle j's Avatar
kyle j
8ft ss fisher worked fine last year went to move plow and when I hook it all up and push any buttos on the fish stick it goes off. If I turn my lights on the fishstick flashes a bunch and goes out and I won't turn back on?
I checked all fuses that I could find and wiggles all wires and nothing.
Old Jul 22, 2016 | 12:00 PM
Kingkong0192's Avatar
Kingkong0192
Have any buddies with a fish stick? I'd swap that first if that's an easy just to rule that out first.
Old Jul 22, 2016 | 12:04 PM
Diesel_Brad's Avatar
Diesel_Brad
Have you check all your connections? The 3 at the grill tend to be the most problematic
Old Jul 22, 2016 | 12:10 PM
kyle j's Avatar
kyle j
Don't think I have any buddy's with one, and I had a buddy wiggle the 3 plugs up front while I watched the fishstick still nothing , I replace the fenders last week would a loose wire at the soliniod cause this?
Old Jul 22, 2016 | 01:12 PM
Diesel_Brad
Yes, any loose wires, missing ground, a pinched wire, etc
Old Jul 22, 2016 | 05:14 PM
tjc transport's Avatar
tjc transport
i ain't rite
99% of the time this is caused by a bad ground.
Old Jul 24, 2016 | 01:44 PM
kyle j's Avatar
kyle j
Is there normally only 1 ground?
Old Jul 24, 2016 | 02:00 PM
tjc transport
i ain't rite
depends on the plow. there should be a ground wire to the plow pump, some have a solenoid to activate the plow pump that would have a ground, and the controller usually has a ground wire too.
Old Jul 24, 2016 | 03:37 PM
kyle j's Avatar
kyle j
So just clean the ground, tighten up wires around the soliniod and got the fishstick to stay on when I push up or down. Problem I'm having now is when I push up or down left or right nothing Happens but fishstick power light is on. Second problem is if I turn the headlights on the fishstick goes off and won't turn back on? Think I might have a wire in the wrong location but can't figure it out what do you think?
Old Jul 24, 2016 | 04:28 PM
tjc transport
i ain't rite
i think those connections look disgusting. i would not be surprised if you were not getting any power to the plow pump.
Old Jul 24, 2016 | 04:31 PM
kyle j's Avatar
kyle j
I can try cleaning them up with a small wire brush? But what about the headlight issue? Seems more than a bad connection or ground? But I don't know much about electrical so?
Old Jul 24, 2016 | 04:55 PM
tjc transport
i ain't rite
still sounds like bad connections. you are going to have to remove the cables and clean them. rust/corrosion in the connection and cables do all kinds of freaky things.
Old Jul 24, 2016 | 05:41 PM
kyle j's Avatar
kyle j
Remove all the cables out of the truck completely? Or just disconnect them from the soliniod and clean them up?
Old Jul 25, 2016 | 05:25 AM
Diesel_Brad
Did you clean the new fender where the ground is attached? Electricity doesnt go thru paint
Old Jul 25, 2016 | 05:45 AM
kyle j's Avatar
kyle j
Yea sanded that yesterday
