Roof height???
Old Jul 22, 2016 | 12:32 PM
johndeerefarmer's Avatar
johndeerefarmer
Try this, a smaller download. I'ts a pdf file and takes awhile to download at least at my 5M speed
http://www.fleet.ford.com/resources/...206_8_2016.pdf
Old Jul 22, 2016 | 12:35 PM
johndeerefarmer
Sorry lets try it again
http://www.fleet.ford.com/resources/...0%20Pickup.pdf
Old Jul 22, 2016 | 02:54 PM
EightySecond's Avatar
EightySecond
Got it, thanks!!
Old Jul 22, 2016 | 04:32 PM
4dogdoc's Avatar
4dogdoc
The info in the link above lists a "medium earth gray" interior color. What trim/color combo is required to get this color interior? I've got a gray interior on my '08 and I love it. The camel is too light & shows dirt, but I hate the black. Too dark & I think the black plastic trim shows scratches much worse than a lighter color. The gray is a fantastic middle of the road, but when I've played with the build & price, I can't get the gray option. I'm wanting a Lariat, so is it just not available with my trim/color choice?
Old Jul 22, 2016 | 07:27 PM
johndeerefarmer
Go here and build one and you can see what's available.
2017 Ford SuperDuty - Build & Price
On edit I see you have already been to the site. It may just be a gray cloth. If so you will need to get an XLT
Old Jul 26, 2016 | 10:55 AM
sdm300's Avatar
sdm300
JDF - awesome, thanks for the link. I've got a whole 1/2" of height clearance, provided the garage door doesn't sag any more and I don;t overfill the tires
Old Jul 26, 2016 | 10:57 AM
johndeerefarmer
No problem. Mine is about the same. I wish for more clearance so am still going to check into swapping the rear blocks for the shorter ones.
Old Jul 26, 2016 | 11:15 AM
EightySecond
Do you think that the math if a truck has 20" wheels would be to just add 1" to the numbers in this pdf?
Old Jul 26, 2016 | 12:21 PM
hollapm's Avatar
hollapm
Switching from a 4" block to a 2" inch should only lower the cab a little less than an inch, not a full 2 inches. Seeing that the cab is centrally located between the wheels you will only be able to take out a part of the bed height difference from the cab. I imagine that you already knew this but wanted others to think about it as well.
Old Jul 26, 2016 | 01:54 PM
Rasalas's Avatar
Rasalas
It might be less money to re-trim the garage door. Maybe even cheat a little off the header if it is that close.
Old Jul 26, 2016 | 02:09 PM
johndeerefarmer
I don't remember exactly how I framed it. I remember sandwiching a piece of steel between two 2x10's and bolting all of this together to make a 20' beam (since my door is 18'. For my 15 SD I had to remove the 3/4" redwood trim and replace it with rubber but this truck is going to be even taller.
I have had to modify several doors around here for the tractors so anything is possible.
Old Jul 26, 2016 | 02:15 PM
Rasalas's Avatar
Rasalas
Steel and Wood = Flitch beam. Can't go too high without extending the door. You could bolt an angle iron to the inside and then cut through the steel and all, or raise the beam up and retrim the jambs too. I am just thinking of modifying your truck and then having to repeat in a few years for the next truck. Maybe just put up a new building with a 13'6" door for the next generation Super Duty.
Old Jul 26, 2016 | 02:22 PM
  #28
johndeerefarmer
Without measuring again the current opening is 82". So I would have 2" overlap at the top. About another inch is all I would want to go up.
I have one shop 20' in front of the house that it would fit in and one about 25' behind it that it would fit in. It's just the idea that it's convenient to walk out the door jump in the truck and not get wet and it easy to get groceries into the house.
Wonder what an air ride system would cost? I could drop it down when I got to the house and on the highway when not towing for better fuel economy? LOL
Old Jul 26, 2016 | 02:26 PM
  #29
fordmantpw's Avatar
fordmantpw
Just jackhammer out the concrete!
Or, put in an air compressor to automatically lower or raise the air pressure in the tires at the push of a button (similar to Hummers of years past).
Old Jul 26, 2016 | 02:31 PM
  #30
Rasalas's Avatar
Rasalas
Or jack up the whole garage!
