Push rod length
Old Jul 21, 2016 | 06:06 PM
Oldschool2888's Avatar
Oldschool2888
Push rod length
I need to find a way to collapse hydraulic lifters on a 390 engine with non adjustable rocker arms when they are pumped up .I need to check to see if I have the correct push rods. I just started the engine (newly rebuilt) have valve noise any ideas on this would be appreciated. Stock ford had three lengths stock .060 under and .060 over. Thinking about push rod checkers there adjustable may be able to collapse lifter? Jerry
Old Jul 21, 2016 | 07:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/67 390 Passenger Car & 1968 390 Passenger Car before change L10 / 1968 F100/350 360/390 before change L2:
C4TZ-6565-B .. Pushrod-standard 9.62 O/A length.
C8AZ-6565-A .. Pushrod .030" U/S
C4TZ-6565-D .. Pushrod .060" U/S
C4TZ-6565-D .. Pushrod .060" O/S
1968 390 Passenger Car from change L10 & 1969/71 390 Passenger Car / 1968 F100/350 360/390 from change L2 & 1969/76 F100/350 360/390:
C8AZ-6565-A .. Pushrod-standard 9.59" O/A length.
C4TZ-6565-B .. Pushrod .030 O/S
Info from: 1965/72 Ford Passenger Car Parts Catalog / 1964/72 & 1973/79 Ford Truck Parts Catalogs.
Old Jul 21, 2016 | 07:50 PM
john jamieson's Avatar
john jamieson
You might also ask on the FE forum further down the page.
Old Jul 21, 2016 | 07:53 PM
NumberDummy
You need 3 Ford parts catalogs to find out what the 390 pushrod lengths are. Besides myself, how many other people that frequent the FE forum have any?
See post #2.
Old Jul 22, 2016 | 04:40 AM
Crop Duster's Avatar
Crop Duster
The tool you need is a Ford (T58P-6565-A), good luck finding one. All of the cam manufactures (Comp, Crane, etc.) have pushrods in any length you could possibly need. If the engine was rebuilt with a performance cam the base circle could be smaller than stock and cause the pushrods to be to short. But before you get to far into the pushrod thing remove the valve covers and run the engine and make certain that the pushrods are rotating if any of them are not rotating one or more of your cam lobes may have failed. Been there, done that, an it ain't no fun.
Old Jul 22, 2016 | 08:27 AM
john jamieson
I suggested the FE engine forum due to the people on there who are rebuilding them. The OP could get some more useful info on other products and tips.
You are an amazing source of info. I was able to find an replacement axle retaining plate for my dana 44 because of you. Thank you.
john
Old Jul 23, 2016 | 10:09 AM
gangstakr's Avatar
gangstakr
See post #2.
Really? after all these years, your still stuck on yourself? Come on Bill your better than that. Times change, people change. Your information is valuable, however your not the only one that gives out information.
Lighten up a little, it goes a long way.
We love and respect you, but sometimes (In your mind) you think your the only one with answers.
Be kind and give without sarcasm or "Besides myself" who has this information? You'll realize, as I have, that there are other knowledgeable people on these boards.
We learn from each other, Just be informative without being condescending.
Zerostyles
Aug 1, 2019 06:33 PM
blacburn10
May 29, 2014 08:31 PM
Rabbit72
49
May 26, 2014 09:15 PM
karjunkie
Dec 2, 2012 08:22 PM
DutchB100
May 24, 2011 04:55 PM
