SuperHitch receiver hitch customer testimonial
See what Don Clemons had to say about the SuperHitch and SuperTruss Extension in the video below:
Don improved his hauling capabilities with the SuperHitch and you can too! The SuperHitch Magnum 30K is rated at 3,000 lbs tongue weight, 30,000 lbs pull with weight distribution and 20,000 lbs pull and 2,500 lbs tongue weight carrying.
Most applications don't require drilling and are compatible with industry standard ball mounts.
It uses our patented dual receiver design (2 1/2" upper and 2" lower) high penetration dual shield welding and includes hardened reinforced hitch pin locations. The SuperHitch Magnum 30K has a Legendary Lifetime Warranty and is proudly made in the USA.
†12,000 lb. pulling capacity, 1,200 tongue wt. achieved only when used with weight distribution type system. See Dealer for details, Weight carring capacity on 48” extension, 6,000 lb. pull, 600 lb. tongue wt. Consult your vehicle owners manual for specific towing capacity. Your truck and trailer weight cannot exceed your vechile manufacturers towing, cargo, or GCVWR.
†† (Camper on, camper off, height variance) obtained by using the ball mount in either upper or lower SuperHitch receiver.
For more information visit our website: http://www.torklift.com/shmagnum
- SuperHitch 30K frame mounted receiver rated up to 30,000 lbs pull and 3,000 lbs tongue weight with weight distribution (20,000 lbs pull and 2,500 lbs tongue weight carrying) in either the upper or lower receivers. (When used without SuperTruss extension.) Extension towing capacity up to 12,000 lbs. with 48” SuperHitch SuperTruss receiver extension†
- SuperTruss Extensions available in 8 different lengths from 21” to 48” (Extensions available to 60") (Sold Separately)
- Both the SuperHitch Magnum 30K frame mount receiver and the SuperTruss receiver extensions use Industry standard 2” x 2” ballmounts
- Eliminates the need for two ball mounts ††
- Specific Torklift tie down fits are available for the SuperHitch Outlaw Series
- Legendary Lifetime Warranty
- Proudly made in the USA
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
04-19-2018 02:59 PM
Torklift Sheryl
10-31-2017 12:47 PM
Torklift Sheryl
04-13-2017 03:01 PM
Torklift Sheryl
12-08-2016 06:26 PM
Torklift Sheryl
06-21-2016 03:42 PM
