New Member needs help
Old Jul 19, 2016 | 08:25 PM
tatertot1207's Avatar
tatertot1207
Desperately searching for engine wiring harness for 1988 F350 with 460 fuel injected motor. Tried local wrecking yards and internet, please any suggestions would be greatly appreciated.
Thank you in advance
Old Jul 19, 2016 | 08:46 PM
Lead Head's Avatar
Lead Head
The harness for the 460 is pretty much the same from 1988 through 1996 if that helps.
Old Jul 19, 2016 | 10:04 PM
tatertot1207
Ian- Thank you for the help... I'm located in CA and I am being told that due to the emissions restrictions, that there are different types. Do you know if that is correct? If you are correct it would make my search possibly easier.
Thanks again
Old Jul 19, 2016 | 10:18 PM
Lead Head's Avatar
Lead Head
Actually, I may be wrong in my post. I forgot that there was a pretty major change in wiring starting with the '92 Model Year. The harness is more or less the same, but the way it connects to the cab wiring is different IIRC.
'88-'91 *should* be the same though. Can I ask what is wrong with your harness?
Old Jul 19, 2016 | 10:32 PM
tatertot1207
Of course.... I was hesitant to post my sad story... however here goes. I recently had a new motor installed and it currently has about 1800 miles on new motor... it had a slight hesitation upon acceleration from a stop. I took to have it check and was told that one or more of the injectors was not working properly. I opted to have all of the injectors changed which I had done. Upon the repair shop taking for a drive after the repairs I was told that it caught fire under the truck and the fire was due to a leak of transmission fluid onto the exhaust????. The harness was damaged by the fire. Sorry for the long explanation.
Old Jul 19, 2016 | 11:08 PM
Lead Head's Avatar
Lead Head
Sounds like the shop didn't seat the injector o-rings properly and caught the truck on fire.
Can you post a picture of which part of the harness got damaged? It may be easier to just repair it.
Old Jul 20, 2016 | 06:44 AM
tatertot1207
I can post pictures, however I do not have any at this time I will try to get some today and post tonight. The shop is telling me that it would be easier and more cost effective to replace the whole thing but I am quickly losing confidence in them.
________
Dale
Old Jul 20, 2016 | 10:55 AM
Lead Head's Avatar
Lead Head
keep us updated.
Scndsin's Avatar
Scndsin
Originally Posted by tatertot1207
...I was told that it caught fire under the truck and the fire was due to a leak of transmission fluid onto the exhaust????. The harness was damaged by the fire.
Unless the trans is A) leaking badly or B) overheating & percolating fluid out the dip stick, (which is a whole different set of problems) I don't see how a fire under the truck could easily damage the injector harness.
... I am quickly losing confidence in them.
I certainly would. Especially when they went straight to the injectors as a cause for a "slight hesitation" with nary a mention as to why/how they got there.
...Sorry for the long explanation.
Not a problem. Most of the time its too little info or what's given is clear as mud.
Hope you get it straightened out.
Ragginredneck
Apr 21, 2022 06:39 PM
Pierre St-Denis
Oct 18, 2017 06:59 PM
polar888
Bronco II
Oct 1, 2017 10:13 PM
Bkcochran
Mar 22, 2013 10:29 AM
jgofff350
May 5, 2010 02:22 PM
