94 7.3 n/a idi
Old Jul 19, 2016 | 12:11 PM
quaallen's Avatar
quaallen
94 7.3 n/a idi
I been doing some research but ain't finding much on the n/a 7.3...
I got a 93 crewcab long bed 351w,c64x4....I have it down to bare frame.. .the engine needs manifold bolts all drilled and tapped.. ughgg and I think it's a little on the small side for such a big truck. Anyway I dont want a ps.. I like the all manual engine idea... so I found a 94 7.3idi non turbo with trans.. (it's an overdrive, don't want that probably find a c6 to mate up) for 300$. It has just over 200k and ran when parked 2 years ago...is it worth the money?? My truck needs all new fuel injection lines and both fuel tasks replaced anyway. I can probably get the radiator and support.. he won't sell the instrument cluster....What else would I need?? Dual battery tray no biggie... I can do the swap and all that's included but don't know what them n/a engines are worth...there are more of them then the turbo idi for sale... I just don't really wanna mess with my 351w...I want better torque and mpg..thanks
Old Jul 19, 2016 | 05:29 PM
quaallen's Avatar
quaallen
Oh and.also is the engine crossmembers the same
Old Jul 23, 2016 | 04:47 PM
quaallen's Avatar
quaallen
Nobody has nothing to say??
Old Jul 23, 2016 | 06:48 PM
85e150's Avatar
85e150
Given the nature of this kind of swap the prevailing advise is to sell what you have and buy a diesel truck with the equipment you want.
Old Jul 25, 2016 | 06:56 AM
quaallen's Avatar
quaallen
Then whydo we even have an engine swap section on this forum?? Because if you want a truck with a different engine everyone should just buy a truck with the engine they want.....
Old Jul 25, 2016 | 05:31 PM
85e150's Avatar
85e150
Some swaps make sense. 302 to 351w. 351m/400 to 460 for example. A high mile truck and a high mile gas to diesel imo does not make sense.
Old Jul 25, 2016 | 05:42 PM
quaallen's Avatar
quaallen
Fair enough... but the truck was a city truck and only has 130k... diesel has 200k...just broke in
Old Jul 25, 2016 | 11:52 PM
85e150's Avatar
85e150
Ran when parked 2 years ago. 200k + how many hours idling? Plus all the other changes including fuel, cooling, exhaust, frame and suspension. And more.
Old Jul 26, 2016 | 08:47 AM
quaallen's Avatar
quaallen
Thank you for your debate.. as I have no-one else to discuss this with.. but let me continue....the truck Is a one tone and I plan on messing around with the suspension anyways.. it needs all new fuel lines and anew front fuel tank regardless .. and it'll need new exhaust from the rear of cab back...all these things need to be done regardless if I go diesel or keep the gasser......
Ive also seen a 7.3 idi with 120k.. but no transmission and twice the price... I'll have to rebuild the heads / top end of the Windsor because all the exhaust bolts are busted and well have to take it apart more then likely.... I just keep thinking diesel is going to be better in the long run... it's going to be the same amount of work basically......
Old Jul 26, 2016 | 06:28 PM
quaallen's Avatar
quaallen
How about one for 600 with only 80k??? Think that is worth my time
Old Jul 26, 2016 | 11:31 PM
85e150's Avatar
85e150
Sorry it's hard to give you a decent reply as I am out of town and using my phone. I check this again later in the week.
Old Jul 27, 2016 | 03:32 AM
tjc transport's Avatar
tjc transport
i ain't rite
a good running IDI is usually around $500 to $1000. then you need to add $200 or so for the trans.
gas to diesel swap is going to need a lot of parts that will get expensive real quick without a donor truck.
you will need a radiator and support. under hood wiring harness. not sure if you can use the in cab wiring or not.
diesel tach. fuel lines. engine mounts and towers. exhaust. driver side battery tray.
plus a few other things i cant remember rite now. then once you get it in, you will be looking for a turbo to put on because the non turbo trucks are slow.
Old Jul 27, 2016 | 01:03 PM
quaallen's Avatar
quaallen
Thank you....I know the trans mission will be my biggest pain....like I said fuel lines are cheaper then fuel injection lines...witch I need.....I'm sure the engine mounts will come with the engine. At least that's how I pull an engine.. I know I will need radiator and core support... I don't think there is under hood engine wiring .... and I don't really need a tach...exhaust is big deal....battery tray is simple... I would like a turbo but in reality it is not needed....I don't care about speed...heck I drive a l8000 every day....so I'm use to going slow. Lol.... my truck Is completely torn apart at the moment....I mean only one xmember is on the frame and nothing else....so as I'm redoing the truck I think now is best to do the swap...I dont want to put the Windsor back in it and spend$ on it then be disappointed and want a diesel....thanks
Old Jul 29, 2016 | 06:26 PM
85e150's Avatar
85e150
What gears are in your truck?
Old Jul 29, 2016 | 07:39 PM
quaallen's Avatar
quaallen
Couldn't tell ya...stock lol...whatever that is....it's not about just the torque....it's the torque and mpg......why do you ask??? I don't missing changing them when time comes
