Factory Tachometer Help
Old Jul 19, 2016 | 02:04 AM
85MOTORSPORTXLT's Avatar
85MOTORSPORTXLT
Well I've decided that I'm gonna put EFI on my 302 in my 85 bronco, and I'm gonna be using the setup from a 89 mustang gt, and I was wondering if anyone knows how to, or has run the factory tachometer with that set up. Lmk thanks Chris
Old Jul 19, 2016 | 06:02 AM
Franklin2's Avatar
Franklin2
Your tach hooks up under the hood out at the ignition module wiring. It hooks to the negative of the coil eventually. The mustang tach hooked up the same, so it's wiring should have a spot for it.
Old Jul 19, 2016 | 08:18 AM
Gary Lewis's Avatar
Gary Lewis
Pages 18 & 19, here: Start, Ignition, & Carb Circuits - ???Gary's Garagemahal. Pay attention to the black wire with light green dots that goes from the distributor to the tach and is marked "8 cyl only". It is a ground that tells the tach to read in 8 cylinder mode. If the ground isn't present it'll read in 6 cylinder mode.
Cornettpd
Apr 16, 2019 10:57 PM
Mitchapalooza85
Mar 7, 2019 12:48 PM
misleib
1978 - 1996 Big Bronco
Aug 24, 2015 10:22 AM
rowdyredneck
Aug 3, 2013 10:45 AM
Jayme
Electrical Systems/Wiring
Apr 26, 2004 08:35 PM
