knock senser
Old Aug 18, 2003 | 03:44 PM
lwpman's Avatar
lwpman
knock senser
I have a 1996 F-150 300. Could anyone please tell me where the knock senser is located. I was told it had a red plug well I have none then. It looks likd a sensor in the block between the coil and the distributer. Might that be it???
Old Aug 18, 2003 | 04:16 PM
bassguy31's Avatar
bassguy31
knock senser
That's it. It's a tough one to get to; you may have to remove the coil.
Old Aug 18, 2003 | 06:28 PM
lwpman's Avatar
lwpman
knock senser
Well thankyou very much!!!!
Old Aug 18, 2003 | 06:35 PM
lwpman's Avatar
lwpman
knock senser
Has anyone ever just unplugged the knock sensor and if so did it help??
Old Aug 20, 2003 | 05:56 PM
javi2001's Avatar
javi2001
knock senser
It doesn't help, because the computer try to put timing as advanced as posible in some conditions, if engine knock, sensor sends a signal to computer and then it delay timing a bit until knock disapear. you usually listen just 1 or 2 knocks before computer correct it.
Regard>
