Sponsored by: Real Truck
Looking for new headlights
Old Jul 17, 2016 | 11:10 PM
Ballistic27's Avatar
Ballistic27
My 1999 F-350 work truck needs new headlights and wanted some ideas or info on doing some new ones.
I really like the 05/07 HD edition headlights, but i do not want to cut anything a little bit of cutting would be fine along as i dont loose mounting holes i guess. Does anyone or ebay ones make ones specifically for the 99-04 area?
Or what are some other good looking headlights?
Thanks!
(already got some ford tow mirrors in the works.)
Old Jul 18, 2016 | 10:31 PM
Ballistic27
Bump, Anyone?
Old Jul 18, 2016 | 11:33 PM
Sam I Am's Avatar
Sam I Am
This guy will probably know
@1ATony
Old Jul 19, 2016 | 01:37 AM
Mike189677's Avatar
Mike189677
You have to cut the header panel behind the headlight to use the 05 lights. It's not a big deal header panel is fiberglass a dremel makes pretty quick work of it. The mounting holes are already there. Not sure what mounting holes your worried about losing. You could also use the 02-04 head lights with the clear lenes. Here is a write up on how to do the 05 to 07 lights you can look through it and decide if you want to do it or not.
?99-?04 Superduty To ?05 Headlight Conversion - Ford Diesel Performance Parts Blog
Old Jul 19, 2016 | 08:00 AM
1Aauto's Avatar
1Aauto
Former Vendor
Here's a link to the Harley headlights on our website if you would like to take a look at them.
F250 Harley Lights
Old Jul 19, 2016 | 01:50 PM
seville009's Avatar
seville009
I had to replace the multi function stalk/switch on my 2011 F350 last year. The ww fluid button on it was slowly dieing, and my wipers started coming on randomly. The switch is basically just a plug in computer board; two small screws held it in. Easy to change out; fixed all my problems.
Old Jul 19, 2016 | 10:10 PM
Ballistic27
I think ill just pull the plug and go for it, Thanks!
Old Jul 19, 2016 | 10:39 PM
Ballistic27
They use a H13 bulb right? While im doing it might aswell get an LED Light kit.
Old Jul 20, 2016 | 01:04 AM
Mike189677's Avatar
Mike189677
Yea they use h13's. With the leds the low beam is good the high beam is useless. At least with the lifetime LEDs that I have. What I would really like to do is have projectors retrofitted for hids the are a few threads on here and they are really impressive. Great highs and lows and razor sharp cutoff. I think you should try the lights with a decent set of halagon bulbs first and see what you think. It will be a huge improvement from your stock lights those are the worst lights output wise you can have on a super duty. If I could find a decent quality halagon bulb that was 5000k color temp I would switch back.
Old Jul 20, 2016 | 10:16 AM
Ballistic27
My other cars have HID Kits, so im pretty used to not having High Beams. But i could always add a LED Light bar, then wire it to be used as high beams if needed. The truck doesn't get driven a lot at night so im not super worried.
Thanks Mike!
BarnieTrk
Oct 30, 2012 08:28 PM
Hiflyer746
Mar 27, 2009 09:28 AM
aklim
21
Mar 6, 2008 04:24 PM
Sportsman
Nov 30, 2007 12:04 AM
Unclemuck
Nov 15, 2005 07:49 PM
