Ive got a closed knuckle dana 44 hd. Im in need of replacment drums and wheel cylinders. Does anyone know if there is a source for these in Canada. The previous owner replaced everything but the drums and now its been sitting so long the cylinders are shot to.
I would suggest Rockauto as well. The prices on the drums for my 66 dana rear were better than any other source and the quality is very good....correct fit as well!
Front drums and front wheel cylinders are different: 3,000 lb. capacity vs. 3,500 lb. capacity front axle.
ALL 1955/65 F250 2WD & 1959/72 F250 4WD have 12 1/8" x 2" front/rear drum brakes.
Beginning in 1966, F250 2WD Camper Specials and F250 2WD's with 7500 lbs. GVWR have 12" x 2 1/2" front/rear drum brakes.
If 1968/72 F250 2WD's have optional front disc brakes, the rear drum brakes are 12" x 2 1/2."
Otherwise, all 1966/72 F250 2WD's have 12 1/8" x 2" front/rear drum brakes.
I remeasured and they are 12 1/8 x 2 dont know how missed this. Unfortunately napa only had a listing for one drum so the hd drums must be unavailable.
I just got the drivers side apart and noticed there is a small cable that is broken. It looks like it holds the lever back that sits on the adjuster screw. Ive checked rockauto and napa it seems you can buy most of the parts separately and as a kit for this axle. I cant seem to find this little cable separately and it doesnt appear in the picture of the kit.
Hmmmm. That looks like the cable for the auto-adjusters. Only thing is I can't think of any 4x4 trucks that came stock with the auto-adjusters in 1961-1966. My 1966 2WD truck has them, but neither of my 1966 F250 4x4 trucks have them.
I thought they were only used with the newer designed 12" x 2 1/2" front/rear drum brakes for 1966 2WD, and then not all 2WD.
The part number for the Brake Shoe Adjusting Lever Cable Assembly is
C6TZ-2A178-A
Which, again implies 1966.
I have at least 9 of those NOS in the packages, but they also reproduce them.
1967 F250 2WD/4WD with 12 1/8" x 2" brakes: First year for self adjusters.
That's what I was sort of half remembering. And then it was a different part number for the adjusting cable than 1966, too, so something to keep in mind if a swap was made at some point, I would think.
C8TZ-2A178-C (replaced C7TZ-2A178-A) .. R & L - Front & Rear Self Adjuster Cable / Obsolete
1967/72 F250 2WD/4WD with 12 1/8" x 2" brakes.
---------------------------------------------------------- C6TZ-2A178-A .. R & L - Front & Rear Self Adjuster Cable / Obsolete
1966/72 F250 2WD with 12" x 2 1/2" brakes / 1967/72 F350 with 12" x 3" brakes.
