95 f250 7.3 largest tires on stock suspension
the stock bumper is the limiting factor for the most part, and probably those running boards on that particular truck.
33's should fit no problem, 35's if you have a winch or custum bumper that doesn't follow the contour of the fender. I run 37's with a 2-3" lift and a winch bumper with plenty of room to go a couple inches bigger.
Yeah I figured I'd have to trim to fit 35s. I like to play in mud so I'd prefer to run 35s if I get it
Misewell get a lift for it, I'm sure the 7.3 has put a whoopin on those stock springs over the years and miles. I'm not a can of trimming.
I moved my axle forward 1.5" and my bumper doesn't return back to the fenders, so that's how I get away with 37s. Fwiw, 35s fit on a healthy sprung stock f350 with no trimming, so the possibility is certainly there with a 250 and a leveling kit at the very least.
The 285s look like a great size on it. But I like making things fit where they shouldn't be able to ( example is my explorer and through a walking trail bridge )
33 Shouldn't Look Bad...
33's shouldn't be bad. The good thing about four words they're not like Chevys are dodges you can generally put some pretty big tires on them most of the time you don't have to level or lift the vehicle. However with how low that truck is I would actually remove the running boards give it a more Fighting Chance at that stance and it may just be enough room to where you wouldn't have to lift the vehicle if you ever wanted too.
