93 F-150 engine swap
Old Jan 17, 2002 | 02:24 PM
460 Joe's Avatar
460 Joe
Post 93 F-150 engine swap
I need to know if I can replace my 220,000 mile 302 in a 93 F-150 with a GT40 302. What will need to be changed with regards to fuel intake, computer, etc? I need more towing power but don't want to go with a 351.
Old Jan 17, 2002 | 03:10 PM
brett_d's Avatar
brett_d
I believe that you have mass air (or should). To check there should be a sensor connected to the air intake that runs to the air box. If you have mass air you need to do nothing for the swap. The only thing that will need to be done is to change the distributer gear to a cast one.
If it is non mass air you will need to do a mass air conversion first!
Old Jan 17, 2002 | 03:45 PM
Pastmaster's Avatar
Pastmaster
Most likely you would have to change to Mass Air, but I believe 93 Mustang's still used Speed Density, so the firing order would be the same on the 302 HO as the regular truck 302s. If this is the case, you would just need to swap the motors. Otherwise, find a donor Mass Air truck with either the 302 or 351 or by the kit.
'93 F-150 loaded and modified!
http://briefcase.yahoo.com/toydestroyer1
Old Jan 17, 2002 | 08:30 PM
orange peel's Avatar
orange peel
Schmitty
17
Sep 12, 2013 12:29 AM
lostin90s
Jul 7, 2006 09:32 PM
fordpower88
Engine Swaps
May 10, 2005 01:05 PM
stinkfist
Jan 29, 2004 09:21 PM
