F250/Bronco single fuel tank conversion
Old 07-13-2016, 05:10 PM
hdfe's Avatar
hdfe
hdfe is offline
So... I've given up trying to make the two tank system work on my '89 F250. I purchased a 33 gallon Bronco tank and I'm in the process of mounting it. I got the fuel pump for the '89 Bronco which is supposed to be a direct fit and went to mount it. The mount plate for the new fuel pump is much smaller and has 3 terminals instead of the 4 pin connector (?) I've gone to Summit, Napa, OReilys and they all show the small plate, 3 pin pump as being the correct unit. Now what?! Has anyone done this conversion before and run into the same issue? Words of wisdom? Set the truck on fire and dance around it???
Old 07-13-2016, 06:33 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
So are you saying the sending unit the parts store gives you for the bronco tank, won't actually fit the bronco tank?
Old 07-13-2016, 07:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I think you want the 90-96 pump with the 3 5/8" bung instead of the 2" 87-89.
Look on Jeff's Bronco Graveyard for pictures.
Electric Fuel Pumps Bronco-Broncograveyard.com
Old 07-14-2016, 11:43 AM
hdfe's Avatar
hdfe
hdfe is offline
Ian, yep... I bought a tank for an '89 Bronc and the bung is a 3-5/8" opening. Could be a vendor error. Ard, looks like JBG has what I'm looking for, even tho' it's $239.00 (gulp) gotta pay to play.
Old 07-14-2016, 02:05 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
That fuel pump there is not going to work at all.
That fuel pump is for a fuel system without the on the rail pump. That pump is a high pressure pump. The stock pump in an 89 fuel tank is a low pressure with the on the rail pump pushing it higher in PSI. You would have to delete the on the rail pump plus I am not sure if the wiring is the same.
I always thought the 3 prong style ones were just a sending unit for carbed engine but I might be wrong.
Trav
WYOF150
10-12-2017 04:21 AM
94mustanggtfast
12-06-2012 07:51 PM
jimjoebob99
09-14-2011 01:59 PM
Kleenax
16
06-18-2009 05:19 PM
MustangGT221
08-05-2006 10:55 AM
Quick Reply: F250/Bronco single fuel tank conversion
