WANT TO TRASH TURN SIGNALS
Good morning. I always forget why my blood pressure goes sky high when I think about working around the grill, headlights and turn signals. Then it hits me......TURN SIGNALS. Specifically the housing. Everything about them is bad either by original design or by misfitting after market parts. Don't try to talk me off of the ledge. I am going to make a change. I'm currently looking for an option of headlights with turn signals built in. Also looking for any aftermarket signal housing not specifically for the '56. What have you men done or seen done? Thanks, Matt
I've seen some sharp looking headlights with LED's in the top corner or on the outside for exactly that purpose. Don't tell the stockers......
http://haloheadlights.co/ProdTurnSignalHeadlights/
My 56 has a 53 grille so I have had some very challenging issues with parking light housings. I am making a mold of the area between the headlight bucket in the grille and the valence panel. I intend to keep the 56 parking light lens but will fabricate the housing from scratch. I wish that I were farther along but unfortunately this task is rather far down the list.
Hey Drew, I always love to see your truck and I like the lights where you designed them. I am going to try to keep whatever I do close to the headlight. At least that's my starting plan. You may hear from me later. Oh wait......where did you access those lights and will they run out of the box with just the standard positive and negative wires? Thanks
» Turn Signals
» Turn Signals
My tail lights came from the same place. Glass cab clearance lights with stainless trim.
7" Projector White LED Halo Angel Eye DRL Amber Turn Signal H4 Headlights Pair | eBay
Do you remember where you found the LED with LED turn signals? Everything that I have found has halogen main beams. eBay has lots of those:
crsweet78
21
08-04-2012 12:37 AM
