There is a range switch on the t-case that is supposed to connect to the PCM to tell it when low range is engaged, but I don't believe a 2wd PCM has an input for the range switch so...
Fixed it!!! with a different (1995) transfer case wire harness.
1991 transfer case wire harness uses a different port to send the LOW/HIGH indicator message on than the 92 does. This is because the 91 has a extra VSS on the Transfer case.
