460 block
Old Aug 18, 2003 | 12:42 AM
SCOTTE123's Avatar
SCOTTE123
Question 460 block
Could any one tell me where I can find an engine block for a ford 460 its for a 86 f250 i live in the seattle area thanks
Old Aug 19, 2003 | 11:56 PM
Superdave's Avatar
Superdave
460 block
SCOTTE123
None in your local wrecking yards? The big wrecking yards in my area don't have them either. You will have better luck at the little not so well known yards as they have older stuff.
I don't know if it matters, but the 79 and up 460's are externally balanced. Which is what the 86 460 would be. I don't know if you are wanting to use the 86 internals to stick in another block. In other words I don't know if the 86 rotating assembly will work in a 78 and back internally balanced 460 block.
Old Aug 20, 2003 | 12:15 AM
SCOTTE123's Avatar
SCOTTE123
460 block
SUPERDAVE Thanks for the reply.
I have found a couple in the junk yards around here
but for 3-5 hundred dollars and your not sure what
your getting( probably need to rebuild).would i be
better off buying a whole rebuilt motor from the local
Ford dealer for $ 2000.00. the motor i have now threw
a rod or two and blew a hole in the block and two in the
oil pan . I assume it cant be repaired?
thanks again
Scott
Old Aug 20, 2003 | 06:57 AM
bremen242's Avatar
bremen242
460 block
$2000 sounds like its a good deal if it was entirely rebuilt..
Old Aug 20, 2003 | 02:10 PM
Superdave's Avatar
Superdave
460 block
SCOTTE123
Is that price for a rebuilt longblock? If so, its probably not too bad.
Its not cheap to build an engine right.
