Moog variable rate spring question
Old Jul 8, 2016 | 10:31 PM
Palmy's Avatar
Palmy
Hey everyone. I have a 76 f250 2wd camper special w/390.
So I'm trying to install the Moog variable rate coil spring but I'm running into an issue with the upper spring mount brackets, they wont fit the new coil. Are the stock brackets supposed to fit these springs or do I need to order a special set?
The top of the new coils are shaped a bit differently then the stock ones but everything says they should be a direct fit. I know, famous last words. Just wondering if anyone has ran into this issue.
I will try to get some pictures to make this a bit more clear.
Old Jul 8, 2016 | 10:36 PM
Jchet729's Avatar
Jchet729
Is it possible that they were packaged wrong.?
Old Jul 8, 2016 | 10:40 PM
Palmy's Avatar
Palmy
I guess that's always a possibility. Moog tech support closed for the weekend before I could call today.
Old Aug 11, 2018 | 07:31 PM
cjbronco's Avatar
cjbronco
Pulling up this old thread as I ran into the same exact problem today. Did you ever find a solution?
Old Aug 12, 2018 | 02:04 AM
1TonBasecamp's Avatar
1TonBasecamp
Can you post a pic of your issue? Is it the wire diameter being the wrong size, or is the shape totally wrong? Like trying to fit a 4wd coil into a 2wd bucket, or vise versa?
Good luck.
Paul
Old Aug 12, 2018 | 07:54 PM
poke em's Avatar
poke em
You bought the wrong springs. The cc808 are for 1/2 ton 2wd trucks and some non camper specials. I made the same mistake last year. These are the correct springs for a camper special
https://www.stockwiseauto.com/acdelc...D=pwf616731g1&
F250DUDE66
Feb 2, 2016 03:28 AM
76Chateau
Nov 15, 2013 08:12 PM
Seabeetough
Mar 25, 2003 02:03 PM
