Rough Idle-Rich mixture?
Old Jan 14, 2002 | 07:57 AM
waltmoe's Avatar
waltmoe
I have a 1992 F-250 with a 460 CI engine. When starting the engine cold the exhaust smokes a little (black smoke) and there is a rich fuel mixture smell. The engine idles very rough when cold then smooths out after it warms up. Any suggestions what is causing the problem?
Thanks
Waltmoe
Old Jan 14, 2002 | 09:04 AM
Avanti's Avatar
Avanti
Sounds like the fuel pressure regulator. Puel the vacum line from it and see if there is any gas. Let us know what you find.
Old Jan 14, 2002 | 11:07 AM
johnny51882's Avatar
johnny51882
Seen it a million times.Your oxygen sensor has taken a crap,that will throw eveything out of wack.could be,just a suggestion.
Old Jan 15, 2002 | 07:52 AM
waltmoe's Avatar
waltmoe
Thanks for the info, I will check it out over the weekend.
Old Jan 15, 2002 | 08:33 AM
chulsey12's Avatar
chulsey12
my truck was doing the same thing about a week ago and i replaced the o2 sensor which didnt do anything for me except cost me 50 bucks, but i changed the fuel pressure regulator and it fixed it, so good luck to you by the way the fuel pressure regulator is about 30 bucks
Old Jan 18, 2002 | 08:19 AM
waltmoe's Avatar
waltmoe
Did the pressure regulator have gas visible from the vac line? Mine does not.
Old Jan 18, 2002 | 10:11 AM
jim henderson's Avatar
jim henderson
imradlol
20
Nov 8, 2016 03:11 PM
Buyerz
Sep 20, 2015 06:15 AM
tomfoolery
Dec 5, 2014 09:41 AM
jade79
Jul 25, 2009 09:19 PM
