Rough Idle when cold
Old Aug 17, 2003 | 10:05 PM
btvnetworx's Avatar
btvnetworx
I am having a problem with my '89 F150 300 not wanting to idle when I first crank it up. It will run for a couple of seconds and then cut off. I have already replaced the IACV. Any suggestions?
Old Aug 18, 2003 | 06:47 PM
zerocash's Avatar
zerocash
Check the plug wires for rust in the ends.
Old Aug 18, 2003 | 07:50 PM
rhetor's Avatar
rhetor
a good tuneup might cure it.
fuel filter and ignition..
Old Aug 18, 2003 | 08:35 PM
paulfix's Avatar
paulfix
Maybe moisture in the dist cap
Old Aug 19, 2003 | 10:05 PM
serving_time's Avatar
serving_time
Moisture in the cap can be a common problem. Is it after sitting overnight (giving moisture lots of time to get in there?).
