2017 Window Sticker
Old Jul 4, 2016 | 09:52 PM
05yuk's Avatar
05yuk
Originally Posted by 2009kr
The derated options are 10,000 and 11,400 lbs. I can you post the sticker? I'm surprised that 11,500 is an option. Still hoping to see 12,500!
http://www.windowsticker.forddirect....8W3BT2HEB13991
Cant get the image to directly post.
This vin was posted on another topic. But it shows 11,500.
Old Jul 4, 2016 | 10:23 PM
Azuretruck's Avatar
Azuretruck
Originally Posted by fidel.medrano
So I have a method of transport and rail tracking information in mine. A date sticks out. "7 01 16" not sure exactly how to interpret everything but interesting. Seems like it has been built...
Did you order a f450 platinum?
Old Jul 5, 2016 | 08:08 AM
fidel.medrano's Avatar
fidel.medrano
Yes. Explanation and picture of Ford Window Sticker
Old Jul 5, 2016 | 08:22 AM
2009kr's Avatar
2009kr
It will be very sad if I need a dually or a Ram 3500 SRW to tow a 15K fifth wheel with 5 people in the cab to stay within my GVWR! [7800# truck + 800# for passengers + 100# misc stuff in cab/bed + 200# for hitch + 3000# pin = 11,900# --> within Ram's 12,300# GVWR, 400# over for the 2016 F350 SRW (and the GVWR on the sticker above)]
I'm still hopeful that Ford won't leave their GVWR 800# lower than the 2016 Ram 3500 SRW with all of the improvements they've made. I'd actually have to go test drive the Ram.
Old Jul 5, 2016 | 08:36 AM
System's Avatar
System
Prolocutor
I agree. It would be sad and make no sense as well. They boxed the frame, swapped the axle, beefed up the springs, increased HP/TQ, and increased the tow ratings but kept the GVWR the same? I don't see how that's possible.
Old Jul 5, 2016 | 10:12 AM
fzrider998's Avatar
fzrider998
Why the surprise at this? This has been known all along, hasn't it? This is all a repeat of the F150...several hundred pounds of weight savings, the GVWR stayed the same, but still net's an increase in usable payload.
The F250 is the same, just less net increase in usable payload...since all the weight savings was re-invested into the frame, axles, etc.
Not to mention these GVWR's are mostly a legality/license registration issue, not necessarily a reflection on the truck's capability...but that's a whole other discussion found elsewhere.
Old Jul 5, 2016 | 10:23 AM
2009kr's Avatar
2009kr
A couple of reasons for the surprise if the GVWR really stays the same. Rodney has stated one, and the other big one is that Ram's 3500 SRW has had a GVWR of 12,300# for a few years. Why would Ford let Ram beat them on the one number that is the problem for those trying to stay in spec for towing a fifth wheel?
If the order guide is correct that the GCVWR for the F250 can be 25,700, it would be almost criminal if the GVWR is 10,000. The truck will weigh less than 8K, leaving a tow rating of 17,700 with only 2K of payload? You'd have to load the trailer very poorly to have a pin that light!
Old Jul 5, 2016 | 11:14 AM
System's Avatar
System
Prolocutor
The 250 has to stay at 10k to remain a Class2 truck. The SRW 350 has room to grow and likely will.
Old Jul 5, 2016 | 11:38 AM
Kenv's Avatar
Kenv
All,
My salesman says he still has nothing for me. Where was the place again where I can enter the order number and dealer number into a "chat" to get info?? Not the window sticker link above, but the one mentioned a few weeks ago. Thanks.
Ken
Old Jul 5, 2016 | 01:26 PM
jackfordsd350's Avatar
jackfordsd350
Did you notice the drivetrain warranty. 5 years 60,000 miles. Is this sticker correct?
Old Jul 5, 2016 | 02:29 PM
System's Avatar
System
Prolocutor
The drivetrain has been 5/60 all along. It the engine only that's 5/100.
Old Jul 5, 2016 | 02:39 PM
fordmantpw's Avatar
fordmantpw
Rodney is correct. FWIW, the '16 stickers say the same thing.
Old Jul 5, 2016 | 03:57 PM
  #28
bowler304's Avatar
bowler304
I was really hoping my window sticker would be available, but I got that it has not yet been made.
My last 5 vin numbers are 17275 which I thought were pretty low, o well will try back later! Thanks again for the information, can't wait and hopefully we get number July 11 when they start building them.
Old Jul 5, 2016 | 05:24 PM
  #29
Rutcutter's Avatar
Rutcutter
My last 5 is 16374 and no sticker yet either.
Old Jul 5, 2016 | 05:31 PM
  #30
fidel.medrano
Can someone take a look at this?
Wouldn't having rail car tracking info indicate a truck was already built?
