Wheel compatibility
Old Aug 17, 2003 | 08:19 PM
checkered180's Avatar
checkered180
Wheel compatibility
Ok, I have a 1966 F-100 sitting on 1979 F-150 4X4 running gear.
Does anyone know if wheels from a 1966 F-250 will fit this truck? Have the bolt patterns and so on changed over the years?
Thanks
Old Aug 17, 2003 | 09:02 PM
mtflat's Avatar
mtflat
Wheel compatibility
Welcome to FTE.
....I'm going to guess 'no' they won't. Ford kept the same bolt patterns for a long, long time - but there are a few variations. The 250 wheels should be 8 bolt wheels.
I have a '73 4x4 and an '86 4x4, both 150's and they have 9" rear ends and 5 on 5 1/2" bolt patterns.
Old Aug 18, 2003 | 07:00 AM
FordBoypete's Avatar
FordBoypete
Wheel compatibility
I don't need to guess, My 66 F100 is on a 79 F150 Trailer Special chassis also. Five lug wheels are the same 5 on 5.5inch pattern since the 40s and right on into the Y2Ks. . . . I took aftermarket custom wheels off my 66, & put them on 79 chassis just fine.
Wheel styles may vary some, but unless you got huge rotors & calipers, or your 4X4 hubs are wierd, wheels should interchange.
Mid 60's wheels are seldom more than 6" wide though. FBp
Old Aug 18, 2003 | 07:08 AM
FordBoypete
Red face Wheel compatibility
To finish, (I punched wrong key & entered my reply too soon) the F250s have been 8 lug pattern since the 40's also. They have remained same gauge also.
BUT as mtflat said answer is NO! F250 wheels will not bolt on to your 79 F150 hubs & axles since they're 5 lug 5 on 5.5 and not 8 lug as on the F250.
You'd have to install F240 4X4 front & rear axle assy's in F150 chassis to make it work. FBp
nerksa
WTB - Parts & other
Jan 10, 2015 09:07 AM
bguy
Sep 19, 2014 05:49 PM
imchillintoo
Apr 4, 2011 01:27 PM
66with352
Nov 3, 2010 10:22 AM
fordgift
Nov 2, 2009 09:55 AM
