Engine Purr when shutting down
Old Aug 17, 2003 | 07:28 PM
Cyberbug's Avatar
Cyberbug
My 302 makes this nice Purr, hissing sound like a vacuum or suction. Only when I shut the engine off, its the last thing you hear.
My wife really likes it.
Should I be worried or this is normal?
Thanks in advance.
Old Aug 17, 2003 | 09:37 PM
84-250's Avatar
84-250
for a hissing, vacuem leak inside the cab check the brake booster, listen for the noise where the brake pedal rod goes into the firewall
Old Aug 17, 2003 | 10:36 PM
Cyberbug's Avatar
Cyberbug
The sound is very prominent on the outside. Not really on the inside.
Its like a pressure release. The truck runs fine. When for a complete checkup when sent it in. Nothing then.
But its kind of a cool sound, only when you shut it off. Its right at the end. Like something is being released. Its louder when the hood is open.
I had some friends check under the hood to try to find out where its coming from. But couldn't really figure it our.
Any one else, have this on their 1994 f-150 5.0L 302 v8
Old Aug 17, 2003 | 10:40 PM
i_alone's Avatar
i_alone
do you happen to have A/C in your truck, if so that is most likley where it's coming from, my dad's 93 does the same thing
Old Aug 17, 2003 | 11:09 PM
Cyberbug's Avatar
Cyberbug
Thanks, It does have A/C. But it always happens even if I haven't used it that day.
Old Aug 17, 2003 | 11:11 PM
i_alone's Avatar
i_alone
your a/c is running almost all the time unless it is in vent or the off position
Old Aug 17, 2003 | 11:32 PM
90f150moneypit's Avatar
90f150moneypit
There is a valve on the pass side near the EGR. Not sure what it is, can't remember. My truck releases the vacuum through this valve at shutdown as well. When I get it back together and running again I'll check to see what this valve is and see if it is normal or not.
BTW, No, this is not the A/C making this noise.
