Hood scoop?
A higher volume of air moving through the engine bay won't be as warm when it exits under the truck and it will cool the engine compartment more.
Mounting the fans in front will make your AC cooler, as well as boosting the cooling capacity of your radiator. There is information about this in the various threads about installing the "Ranger coolant bypass valve." I want to install a couple of those fans on my truck with parallel controls from a thermostat in the engine bay or the coolant system and a relay triggered by the compressor clutch circuit.
I put the bypass valve on my '01. The valve makes the AC noticeably cooler. It also allows you to use the "Vent" position instead of "AC" on marginal days because the air is cooler entering the system. It costs about $35-$60 to do it yourself, depending on how you do it and if you buy a Motorcraft or aftermarket valve.
My truck is an XLT and the most thermal insulation in my cab is the carpeting and felt mat beneath it on the floor. With that in mind, it is logically the best place for the air to exit the engine compartment.
With the fans, you won't have to trouble with hacking up your hood or matching paint.
http://www.dieselsite.com/maxacassis...200373l-1.aspx
The Ranger heater by pass valve is cut into both heater hoses (I did mine under the cowl on the passenger side. A bit harder to reach but I did not have to replace any hoses. The valve you are looking at installs in the heater hose near the passenger side inner fender. It is easier to install. Both valves require either a vacuum line ran to the group of vacuum lines behind and to the left of the glove box or an electric solenoid valve with a switch mounted in the cab. The bugger in either installation is getting the vacuum line or electrical wire through the cab.
I believe the Ranger mod was necessary on the 7.3l diesels to allow proper coolant circulation through the passenger side cylinder head., but not the newer ones. I was following a thread on Power Stroke Nation on that installation but I could have used the valve you linked.
Either mod will make the a/c noticeably cooler. I am very pleased with my installation. However, from what I've read, the valve you selected should have come standard on all Excursions, Crew Cabs after '03 and all trucks starting around late '04 or early 'O5.
So. you have one, replacing it will NOT make your a/c colder unless the valve is not working. First picture in this thread shows it circled in white. https://www.ford-trucks.com/forums/1...ost-vents.html
The fans I mentioned are on the "someday" list so I cannot tell you how they work yet! I've read about 10 degrees colder air temp at the dash.
If you have one, you should be able to check it with a vacuum pump or by attaching a vacuum line to it and trying to suck air through it. Most failures are a ruptured diaphragm so if you get air or it won't hold vacuum, it is bad. If the cam arm is visible you can also switch to and from 'a/c max' and see if the arm moves.
If you Google "heater hose shut off valve 2004 super duty" and click "images" you get lots of pictures....
Keystone Restyling
Another route is to put a larger air dam under the front bumper. This would create a negative pressure area under the engine, which would draw the hot air down and away, also causing more air to flow through the radiator area. The down side is that you'd sacrifice your ground clearance to do this.
That is the valve. It looks "factory" with that type vacuum line and the spring hose clamps.
It has the 'exposed cam arm' I mentioned. If you want to check operation, just start the truck and have someone turn the selector from "HEAT" to "MAX AC". You should see movement on that little arm directly opposite the vacuum line connection.
The line insulation looks like my kind of mod: simple, easy and cheap! I may actually jump all over that one. Only thing is I'm not sure I could stand to have the a/c much colder! But since I installed a solenoid valve I can turn the bypass off and on from the cab, that is not really an issue. The gain would be running the compressor less for better MPG's. At least in theory....
yea the valve works, radiator looks clean and not covered with bugs/crap, i was told to check the evaporator near the firewall next. haven't done that yet, not exactly sure what i'm supposed to check/open/look at yet lol.
but i did run up to home depot and buy some of this, just not the 12" wide stuff. couldn't find what i bought on their site for some reason. I'm probably going to monitor the temps on the vent thermometer i got yesterday for another day or so, then start the insulation on the lines, and see if it helps. i'm sure it will, question is, how much will it help.
E/O 12 in. x 15 ft. Self-Stick Foam/Foil Duct Insulation-FV516 - The Home Depot
i wouldn't mind the a/c getting any colder, if it was ever too cold, i could just turn it to "a/c" (rather than "max a/c") or just turn the center temp **** slightly towards heat. but in all my years there are very few times that i do that, usually if i'm sick or something and my body keeps getting cold/hot, so i have to keep adjusting the air. but i can't do with NO air (other than for a few minutes if i'm freezing), or sometimes early in the AM when i just get up, sometimes im fine with cracking the window before it gets hot. i have my passenger vents closed, and my 2 drivers vents are positioned so they blow air directly in my face. idk if most people hate that, i can for sure say anytime my cousin gets in my car(s), he doesn't like the air blowing right at his face lol. points the vents directly down. i literally get hot, sometimes start to sweat, even if the a/c is on full blast, but not blowing directly at my face. idk why...i guess i just don't like heat at all. i live in the wrong state i guess dont I....lol (florida)....had i not been born/raised here, i'd probably move up north!
