Catalytic Converter
Old Aug 17, 2003 | 06:01 PM
NSANT's Avatar
NSANT
Catalytic Converter
How can you tell if your catalytic converter is had it?If it were gone inside would that cause the floor of the cab to be extra warm while towing a travel trailer?
Old Aug 18, 2003 | 11:55 AM
hhipp's Avatar
hhipp
Catalytic Converter
If the substrate inside the converter is begining to get plugged from deposits then yes this could produce extra heat in the converter due to the restriction in exhaust flow. The extra load given from towing the trailer is causing additional HC or unburnt fuel in the exhaust which will also produce additional heat. If the heat shield between the converter and floorpan is missing that could be your problem as well.
Old Aug 18, 2003 | 05:39 PM
natewoz's Avatar
natewoz
Catalytic Converter
Gently shake the CAT to see if their is broken peices inside. Don't let the heat sheild rattle fool you though.
Old Aug 18, 2003 | 05:53 PM
NSANT's Avatar
NSANT
Catalytic Converter
Thanks.I think I'll have it removed Thursday just to be sure.
