Some issues after upgrading turbo
Old 07-14-2016, 12:41 PM
FordBlueHeart's Avatar
FordBlueHeart
FordBlueHeart is offline
Do you have a standalone boost gauge? Tunes manipulate the stock sensors. I'm not saying this is your issue, just that the info is inaccurate.
Old 07-14-2016, 12:58 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
No I do not I just use the SCT Live Wire.
Old 07-14-2016, 02:35 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
You need a separate boost gauge to get "real" boost levels. Tunes change the levels to affect performance.
Old 07-14-2016, 02:46 PM
Twitchyleprechaun
I will put that on my list. But, I am still slower, getting less mileage, and running higher egt's
Old 07-14-2016, 02:54 PM
Per4mance's Avatar
Per4mance
I kinda like KC turbo's myself. I have a friend that just modded his truck with it and has had zero issues. You may have to call the selling vendor and see whats up. Like Anthony says, He's not a fan of 03 PM
Old 07-14-2016, 08:42 PM
FordBlueHeart
Since you said the issues came after the Powermax, I assume no other values have changed? Are all the values within spec? EBP, ICP and so on? If nothing else has changed, I would contact your vendor.
Old 07-15-2016, 08:45 AM
run6.0run's Avatar
run6.0run
run6.0run is offline
If you find someone that gives a darn about an issue like this (being an online retailer),, let me know,, because I will start buying from them. But we have personally seen how certain places handle this exact issue. And NOBODY stepped up to make it right. Everyone wants to blame everything else. "It CAN'T be the turbo", is what we have heard. Our policy now is,, if you buy a turbo online,, just count on it being your baby.
I ranted above,, but do let us know if whoever you bought this from cares. I've seen how one place out west ,, that you ALL know and praise,, basically gave the finger on an issue like this.
Old 07-15-2016, 03:01 PM
acf6's Avatar
acf6
acf6 is offline
Originally Posted by wedge542
35 lbs, wow i did not know a 6.0 could even stay together at that boost level with only 4 bolts per hole be studs or not.
My friend's 6.0 is staying together running 100 psi and making 1100hp on fuel only
Old 08-24-2016, 09:21 PM
Twitchyleprechaun
Still seeing the 40% increase in egts and now a blown head gasket....on an aleady studded truck. Guess what will not be going back on the truck.....
Old 08-25-2016, 06:23 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
What are you going with?
Old 08-25-2016, 08:23 AM
Twitchyleprechaun
I am just going to rebuild my stock turbo amd put that back in. It was performing great so I should have just stuck with that.
Old 08-26-2016, 07:48 PM
SniperVision's Avatar
SniperVision
SniperVision is offline
I am also seeing lower boost on my pmax than stock turbo. 24 max vs 32. But My 24 feels more like 34 though. So far about the same egts as stock. Just running 8k tune now. Hope u are able to return turbo.
  #28
Old 08-27-2016, 01:22 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
What about air flow in cubic feet... is it flowing more air at less pressure? If that is the case, then it's making more power.
  #29
Old 08-27-2016, 01:42 PM
AGE mechanic's Avatar
AGE mechanic
AGE mechanic is offline
Does GearHead change parameters of his tunes if someone has a PowerMax turbo? It should be supplying more air, so does it need more fuel?
  #30
Old 08-27-2016, 01:47 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
They do write tunes specific to the powermax.
Quick Reply: Some issues after upgrading turbo
