Sponsored by: Auxito
Help!
Old Jun 30, 2016 | 07:12 PM
docsox4701's Avatar
docsox4701
Exclamation Help!
So I have a 98 f150 with the 4.6L V8. Been having some issues with it, first off it gets the standard film on the windows associated with a bad heater core, it doesn't leak fluid into the truck tho. But it does have an issue with heat. Also while driving the coolant system develops an air bubble and pushes fluid out the over flow. Also it periodically registers that it's over heating and goes into limp mode. if you press in the clutch and turn the truck off it resets and acts as if nothing ever happened. Please point me in the right direction
Old Jun 30, 2016 | 08:51 PM
steve(ill)'s Avatar
steve(ill)
first thing to do is check for exhaust gas in the radiator coolant system. There are meters to do that.. Next, how often has the antifreeze been changed ? Radiator flushed? Heater core flushed ? Thermostat changed ?............. Some of the older 4.6 with OLD antifreeze have been noted to eat the water pump impeller... If you have not changed the antifreeze in some time, or keep adding tap water, the radiator and heater could be partly plugged..
Old Jun 30, 2016 | 09:29 PM
Sycoholic's Avatar
Sycoholic
If fluid is being pushed out the overflow it's either boiling out from overheating or you have a head gasket that no longer gaskets. I know O'REILLY Auto Parts rents an exhaust gas tester and I would imagine other parts stores do too. That's where you need to start. Next I would think overheating. If you have poor flow, perhaps due to a blockage, it will cause a hot spot that will give you similar symptoms. While you're at it, a new cap couldn't hurt.
Bluecounty
Feb 14, 2018 05:20 AM
PSYCHO BOB
1978 - 1996 Big Bronco
Dec 11, 2009 09:24 AM
websthes
Sep 20, 2007 01:32 PM
pr95bronco
Dec 24, 2004 09:36 PM
lawless
Jan 13, 2003 10:06 AM
