Vented gas cap?
Old Jun 27, 2016 | 02:36 PM
JimG1098's Avatar
JimG1098
Vented gas cap?
Hi gang. Beautiful weekend for a drive.
The other day, truck was a little stubborn to start. This truck starts the instant you hit the starter. This particular time, it was acting up a little. I checked the see thru gas filter and there was room at the top. Normally, it is full . I opened the gas cap and heard a whosh. Now, the cap I have is supposed to be vented, according to Mid Fifty. Since then the truck is running great. Drove about 40 miles yesterday. ( Background New tank, lines, rebuilt fuel pump. I do not understand why pressure ( or vacuum ) is building up if it is a vented gas cap. It appeared like a plastic gas can you leave out at night and in the morning it is all sunken in. Any ideas or help would be appreciated.
Old Jun 27, 2016 | 08:20 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
A vented cap is designed to replace air in the tank as fuel level drops but it is not supposed to allow gas vapors out. So tanks can build pressure as they warm up if they are just sitting. So was your whoosh an inny or outy whoosh?
Old Jun 28, 2016 | 09:20 AM
Connecticut Calvin's Avatar
Connecticut Calvin
If you want to verify that your gas cap is in fact vented simply remove it and put your mouth over the center hole (on the gas tank side) and suck in. If you can suck in, it's vented. If not, it isn't vented or the spring is faulty. Note: You shouldn't be able to blow out as the vent only works one way.
Old Jun 29, 2016 | 11:33 AM
JimG1098's Avatar
JimG1098
Thanks Dave and Calvin. My internet has been down for a little bit. Rain in the cable. They are still working on that issue.
I checked the other day, It appears that it is an outward whosh. I will try right now to try sucking in on it. I will let you know how I make out. In the mean time Mid fifty is sending out another cap. They have been good to work with.
Thanks again
Old Jul 1, 2016 | 05:01 PM
petemcl's Avatar
petemcl
This might help you:
Old Jul 2, 2016 | 06:25 PM
JimG1098's Avatar
JimG1098
Calvin. Thanks. Performed that test. Cap is working properly.
Petemcl. Thanks for the drawing. that explains a lot
Old Jul 3, 2016 | 09:59 AM
JimG1098's Avatar
JimG1098
So I am not really sure what transpired with the tank the other day. Possibly, the cap could have got stuck once. In any case, I put the new cap on it from Mid Fifty, All seems good. The one thought is that there could be some type of a blockage in the tank, but as i said, everything was new. I'll just have to see how it goes. I wish I had one of those long flexible camera things. I would look in the tank.
swanronson
Oct 2, 2017 04:22 PM
Pdxjacob
May 9, 2016 01:57 PM
Sportsterengr
Apr 18, 2016 02:29 PM
69supercj
23
Aug 8, 2015 08:36 AM
Cowboy_351
Garage & Workshop
Apr 15, 2002 04:15 AM
