What is the purpose of a riff raff panel replacement
Old 06-26-2016, 12:49 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
I've always liked the manual version more myself as well FWIW.
Old 06-26-2016, 03:01 PM
Peace2Peep's Avatar
Peace2Peep
Peace2Peep is offline
I love that gun holster Twitch! I don't have the cojones to have it!!!
Old 06-26-2016, 03:15 PM
norman2012's Avatar
norman2012
norman2012 is offline
Originally Posted by Twitchyleprechaun
I use the manual version just because I liked the look of it over the auto. I use it for lights and power. I now have the foot adjustment switch in the hole that is on the left.
Where did you get that holster and who makes it?
Old 06-26-2016, 06:46 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
It was the cheap holster and speed loader that came with the XD. I cut the speed loader down to just the rail and used that to mount to the dash. The holster clips right into it.
Old 06-26-2016, 09:53 PM
norman2012's Avatar
norman2012
I'm impressed at all the modding and fabricating that goes on here
Old 06-27-2016, 02:41 PM
norman2012's Avatar
norman2012
WHere did dyou order those switches
Old 06-27-2016, 08:29 PM
Twitchyleprechaun
Amazon. Just search rocker panel switches and be prepared for a ton of options.
Old 05-01-2018, 01:22 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Sorry to drag up an old thread but is there room on the manual trans upfitter panel to mount a 2" gauge in on the flats?
Old 05-01-2018, 02:23 PM
96firephoenix's Avatar
96firephoenix
96firephoenix is offline
Riffraff Diesel Custom Manual Dash Kit
they've got a picture of 2 gauges on the lower flat in this one... says they are 2" gauges
Old 05-01-2018, 02:28 PM
EXSwap's Avatar
EXSwap
EXSwap is offline
Did a little digging and this is the most direct answer to your question...
It also appears that the "standard" gauges from places like glowshift are 2 1/16" diameter, so if that's what everyone is using in their conversions, I'd be willing to bet they'll fit.
Edit: Beat me to the link!
Old 05-01-2018, 10:03 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
I have 4 x 2-1/16 gauges mounted on the flats. Two on top, and two on bottom. I also have my hydra switch on the top left where the oval cut out is, and I have a little, round voltage display on the lower right.
Use a hole saw to make the cut-outs for the gauges. Run it in reverse for a second, then run it forward to cut. I used a 2" hole saw (no one carries a 2-1/16 in stock), and then enlarged the hole with a Dremel sanding barrel. You can get 3 gauges on each flat if you wanted to.
Old 05-02-2018, 10:20 AM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
>is there one other than the ability to have more switches and gauges?
What kind of stuff could an excursion owner need 9 switches for? Or 3 for that matter? And gauges? I saw where one x owner put a phone cradle where there normally go two gauges, would a note 5 cradle fit there?
Because America, that's why.
  #28
Old 05-02-2018, 10:30 AM
ArmyLifer's Avatar
ArmyLifer
ArmyLifer is offline
Here’s mine...
  #29
Old 05-04-2018, 06:40 AM
Twitchyleprechaun
Nice. I was at first worried about having the brake controller that low, but I jist kept practicing reaching for it in case of emergency and now it doesnt feel that awkward.
I redid mine a little while ago do clean it up a bit.
I am also worling on changing the color of the entire dash. I like the lighter color of the panel.
  #30
Old 05-04-2018, 08:16 PM
norman2012's Avatar
norman2012
What brand gauges are those?
UOTE=ArmyLifer;17961075]
Here’s mine...
[/QUOTE]
Quick Reply: What is the purpose of a riff raff panel replacement
