High Idle Mod
Old 06-24-2016, 07:46 PM
Joe/GA's Avatar
Joe/GA
Joe/GA is offline
High Idle Mod
Hey guys, my wife has COPD and doesn't breathe well in hot and/or humid conditions. Sometimes, I'm leaving my wife in the truck with the air conditioning running for 5, 10, 15 minutes while I run into a store or get the camper hooked up to shore power. I understand a high idle mod is better for the engine than idling at regular speed. Most folks want the high idle for warming up the truck in cold weather. Am I right in thinking that I need the mod if I'm going to continue having my wife sit in the truck with the engine and AC running?
Old 06-24-2016, 08:25 PM
Dakster's Avatar
Dakster
Dakster is offline
Long idle times in warm weather, the high idle mod is the right thing for. In cold weather, the engine will high idle on its own due to temperature. (even though the high idle mod is still beneficial in cold weather for long idle times)
I don't really see a huge issue with the 5-15 minute idle times. Especially if you are going to be working the truck afterward - as in - pulling the camper.
Basically what you are trying to prevent is wet stacking, simplified, it's fuel washing past the cylinders instead of being burned.
if you are really worried, a good way to tell if you are harming your motor is a used oil analysis (UOA) . I don't typically get those done, but a few people do. If you are getting a lot of fuel in the oil, extended idling could be the cause.
Old 06-24-2016, 09:24 PM
Joe/GA's Avatar
Joe/GA
Joe/GA is offline
Thanks Dakster. That's how I was thinking. As cheap and easy as the high idle mod is, I might as well do it.
Old 06-25-2016, 10:23 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
I love the high idle mod! I used the one that Brandon set up for me. Using posi-taps makes it much easier for those with bigger hands underneath these dashes.
Old 06-25-2016, 12:43 PM
Joe/GA's Avatar
Joe/GA
Joe/GA is offline
Is yours adjustable or fixed speed?
Old 06-25-2016, 01:00 PM
golfmedik's Avatar
golfmedik
Mine is adjustable. I put mine on a potentiometer.
Old 06-25-2016, 09:13 PM
Ultratravler's Avatar
Ultratravler
Ultratravler is offline
Is this a dealer or after market mod? Thanks.
Dave
Old 06-26-2016, 03:57 AM
golfmedik's Avatar
golfmedik
Here is a "How to" from the Tech Folder in this section.
https://www.ford-trucks.com/forums/1...ml#post9494561
Old 06-26-2016, 08:42 AM
Nipperdog's Avatar
Nipperdog
Nipperdog is offline
I use the High Idle Mod all the Time here in Florida. When the Wife goes into the store, I kick it on via upfitter #3 Sit back and listen to Sirius. I keep mine set to 1200 RPM.
Old 06-26-2016, 09:16 AM
golfmedik's Avatar
golfmedik
Same here. 1200 rpm and she purrs just fine.
Old 06-27-2016, 04:09 PM
Gunshotwoundshurt's Avatar
Gunshotwoundshurt
Gunshotwoundshurt is offline
Anybody know ( besides radio shack ) where to get the 20K ohm resistors ? Haven't had any luck finding them.
Thanks in advance.
Old 06-27-2016, 05:16 PM
Joe/GA's Avatar
Joe/GA
Joe/GA is offline
Thanks in advance.
GOOGLE is your friend!
Here is one place:
20K Ohm 1/2W Flameproof Resistor 10 Pcs.
Old 06-27-2016, 07:18 PM
Ferguson65's Avatar
Ferguson65
Ferguson65 is offline
Thanks in advance.
A pot only takes at little extra time to do, and is worth it. These trucks idle really poorly around 1100 rpm. I have a pot and like most mine is set around 1200. I use it all the time in SE PA.
Old 06-27-2016, 08:26 PM
Joe/GA's Avatar
Joe/GA
Joe/GA is offline
I installed my pot today. I used the 50K ohm pot that so many other guys have used. It works well, but the speed range is unreal. When I turned the pot I went way up close to 3000 RPM. I think 1200 RPM will be the sweet spot. However, I wonder how it would work if it was done like the SVE Bulletin shows with a 5K pot and a 240 and 360 ohm resister in series with the pot like below.
Eliteac
6.7L Power Stroke Diesel
82
04-21-2014 06:40 PM
brandon.edwards
01-17-2013 07:51 PM
Lonzom10
6.4L Power Stroke Diesel
06-06-2011 10:42 PM
powerstroker100
04-26-2010 10:01 AM
Krisx125
12-08-2009 11:49 AM
Quick Reply: High Idle Mod
