So I had my oil cooler replaced @ 89k miles. Now I am at 136k miles. Oil coolers don't go out that fast do they? I had one from Ford installed, what I don't understand.....is my ECT/EOT delta is anywhere from 12* to 22*. The fan clutch is ALWAYS on. I checked coolant levels, I don't have oil in coolant, coolant in oil. I don't understand. My coolant level doesn't move. However I can be just moping along and my EOT/ECT while UNLADEN is 15*. I have my EGR deleted. But that shouldn't cause THAT big of a problem. Any suggestions guys?
Do you have a coolant filter installed? Are you using Ford "Gold" coolant? Are you changing it often?
If you are using Ford Gold coolant, and haven't changed it in awhile, and you don't have a coolant filter, you may need a new cooler again.
Most people here do the following when the delta reaches where you are at.
Flush with VC-9
Change oil cooler
Install bypass coolant filter
Change coolant to ELC
Check/change coolant regularly
People who do this rarely have problems afterward.
Yes, your oil cooler can be clogged again. It all depends on how well the coolant system was flushed during the previous cooler swap.
I did what ThorsHammer posted and followed to instructions in the tech folder for flushing out the coolant system. But like posted above it would be good to know the actual temp readings as well to verify the sensors are operating correctly as well as the thermostat.
So when I'm towing my 9k lbs camper. I see ECT of 218* and EOT of 238*
Your temps while towing don't mean much, what are they unloaded while driving @ 65 on level freeway for 20 minutes or so. That's 20 minutes after it's up to full temp.
......................... However I can be just moping along and my EOT/ECT while UNLADEN is 15*.................
After rereading the thread again this is the part that still concerns me a bit. Like suggested above, I would do the 65 mph unloaded test and do some data logging with Torque Pro for some piece of mind.
If you data log, ECT, EOT, RPM, & speed we can graph it up and get a better understanding.
