Cam Specs ??
Old Aug 17, 2003 | 03:04 AM
Katmandu2's Avatar
Katmandu2
Cam Specs ??
What are the Specs on the OEM EFI Camshaft ??
How does it compare to the CompCams in the pic below ??
Old Aug 17, 2003 | 03:10 AM
Katmandu2's Avatar
Katmandu2
Cam Specs ??
Here's what Crane has got.....
http://www.cranecams.com/truck/503905.htm
PowerMax
H-260-2 204/216° 260/272° .458/.487" 112°
And here's Crower's.... See Pg.59
http://www.crower.com/pdf/53-104.pdf
Old Aug 17, 2003 | 09:09 AM
StrangeRanger's Avatar
StrangeRanger
Cam Specs ??
The stock camshaft for a late 300:
.249" lift at lobe, .401" lift at valve
268° advertised duration
either 192° or 194° duration at .050" lift, I forget which
111° lobe center angle.
4° retard
